A few months back I had a Metro zero-loss FX loop fitted to my JMP 2204 by a reputable amp tech. The loop itself works brilliantly, but the amp has developed an annoying hum in some situations. So far, I've managed to identify the following:
- It's nothing to do with the guitar as the hum is present with nothing plugged in.
- It's not affected by any of the controls, with the exception of the presence; it's greatly reduced with the presence full up.
- It occurs at home and at my Dad's house, but is much less noticeable at our rehearsal room; there I have to get right up close to the speaker to hear it.
That last point makes me think it's environmental - so is it:
- A shielding problem? Whoever built the head enclosure added a metal panel on the bottom, but it doesn't go all the way across and enclose all the circuitry.
- A mains problem? Would a mains conditioner improve it? (I tried turning the fridge off, as I know they can cause issues, but to no avail.)
- Unlikely, I know - but the cab? As that's the only other variable between home and the rehearsal room.
TIA.
Asking because the presence control is part of the power amp negative feedback loop which is derived from the speaker output - from the 4-ohm tap, although it affects all of them.
Here's a picture I took just before I fitted the Aluminium Plate along the bottom of the Amp . .
https://i.imgur.com/eWStYFB.jpg
Feedback : https://www.thefretboard.co.uk/discussion/58125/
If the loop is grounded to the speaker ground then that might explain the hum.
Is the hum affected by the gain or master volume?
Adding shielding willy nilly might solve the problem, or might just make it bearable, if you can track down where the hum is coming from then it you eliminate it
That said, its absolutely no secret that at the same time I'd added the additional screening and made the Aluminium Box to fit around the Controls Area, as well as replacing all the Valves with new or nearly new, Nigel . . . . my good mate and Amp Tech had also replaced all the Filter Caps and fixed anything that looked remotely electrical :-)
Despite all the Amp Tech's painstaking work, I'd still like to think that it was "mostly" my efforts with the sticky backed silver Aluminium Foil that got the job done :-) and Nigel, if your reading this, the cheque is in the post . . .
Have you asked the tech who installed it about the hum?
When I mount these types of loops I mount them closer to the top rather than forcing them onto the same C/L as the speaker sockets.
These loops pick up noise from the sockets when mounted directly over them. So the more distance the better
What I don't get is - either the hum is reaching the speaker via the speaker cable, or through the air. If it's the cable, why does turning the master right down not get rid of it? And if it's EM interference, you'd expect the shielding to reduce it, at least. I even made up a long speaker cable so I could separate amp and cab, and it's the same.
Stumped.
We've got another rehearsal room booked for tomorrow, so I'll take it along and try it.
Because the hum is coming from the power section, and the MV is before the power section - but the presence control isn't, which is why it affects it.
No, because even if it's electromagnetic coupling, shielding isn't effective against the magnetic component, only the electrostatic. (Unless it's Mu-Metal.)
