Tips for getting a velcro'd front off a closed cab,..
lovestrat74lovestrat74 Frets: 2526
Got a closed cab so access to the speaker is via the front velcro'd baffle, but how the f do you get it off. There must be an easy way right???
  • ecc83ecc83 Frets: 1631
    Slowly I found is the trick. get a thin, flat object under the front, a fish slice is ideal, and make steady,slow upward actions to free the velcro. Tackle just one area at a time and if you can get another bod to help with their kitchen tools, so much the better.
    Dave.
  • bertiebertie Frets: 13568
    Dave.
    this  -   My chub is front loaded,  so have done this a couple or three times
  • richhrichh Frets: 450
    Flatblade screwdriver, or any other suitable object to prise off
    Yes, works but you have to be very careful not to bruise the cabinet with the narrow shaft.
    Dave.
  • lovestrat74lovestrat74 Frets: 2526
    Dave.
    Dave, you legend! Went in armed with a fish slice and a metal spatula! There is no way this was coming off with a screwdriver. This thing was tight and took some doing, but with perseverance and sheer determination I got if off  :#
  • ICBMICBM Frets: 72315
    Don't do that, you'll chew up the edge of the cabinet.
    Does the cabinet have a logo that's held on with screws? If so, remove the logo, and drive a short fat self-tapping screw into the area under it, leaving the head sticking up a bit. Then use a flat piece of wood to protect the edge of the cabinet and act as a leverage point, and a claw hammer or short crowbar under the head of the screw to pull the grille out.
    If it doesn't, the fish slice or similar tool is your best bet.
    IC, don't think we are talking about a "grill" more a full sized speaker fret covered board? I seem to recall the Series One 45 used one?
    Dave.
    I think we're talking about the same thing... a frame in front of the baffle, covered with fret cloth, recessed into the front of the cabinet in which it's a tight fit. If the velcro holding it is strong - or worse, Dual Lock - you usually can't simply pull the grille out, even with those annoying loops of cloth some manufacturers fit.
    I've long since lost count of the number of these I've seen with screwdriver marks in the edges of the cabinet where people have tried to lever them out. The screw 'puller' method works perfectly, although to do it completely invisibly you do need a removable logo - preferably screwed on, although a pinned one can be removed with a flat blade.
    This method also works to remove stuck back panels where they're either too tight a fit in the recess or the vinyl has gone soft and semi-glued itself - you need a very fat screw, and put it into one of the panel screw holes.
  • hywelghywelg Frets: 4303
    Dave.
    I always used to carry a fish knife in my pedalboard bag for just this purpose.
