Grover 205C & 305C Rotomatics
kswilson89kswilson89 Frets: 222
edited June 2022 in Making & Modding
Hi
I've just bought an early 90s Les Paul special which has Grover mini rotomatics (205C) as stock. Just wondering if anyone knows whether the mid-size 305C's would be a drop in replacement?
Thanks
  • GluedtoMusicGluedtoMusic Frets: 74
    edited June 2022 tFB Trader
    No the 205 has the screw offset downwards in a different position to the 45 degree angle of the 305 screw (you would need to plug and redrill the mounting screw hole),
    https://grotro.com/wp-content/uploads/205.pdf
    https://grotro.com/wp-content/uploads/305-1.pdf
    Supplier of Gotoh, Fender, Gibson, Faber, Schaller, Hipshot, Floyd Rose, TonePros, Graph Tech, Hosco luthier tools and many more.
  • kswilson89kswilson89 Frets: 222
    Thanks for the info, do you know of any tuner that would be a direct replacement for the Grover 205C?
    Schaller M6 180 tuners have the same screw placement as the 205
  • ICBMICBM Frets: 72460
    Why? If it’s because the keys look and feel oddly small on the Gibson headstock, it might be easier to find just a set of replacement keys.
    Thanks for your help!
    It's mainly because I'd like something with a higher gear ratio but the buttons are fiddly too. Maybe I'll try changing them first.
    Bigger keys will feel like they have a slightly higher ratio because it's easier to turn the outer part of the key by a smaller percentage of the rotation, if that makes sense!
    But if that's the major problem, the Schallers are probably the bigger upgrade - they're actually just a better quality mechanism than the modern Grovers. (As are Gotohs.)
