Chord inversion charts
DannyPDannyP Frets: 1682
Anybody have a link to some charts with maj7, min7 and dom chord 1st, 2nd, 3rd inversions? Drop 2, drop 3 etc.
Preferably printable.
My google skills are failing me, I'm just finding a thousand variations of root-on-the-bottom chord boxes.
  • DannyPDannyP Frets: 1682
    UMPB
  • digitalkettledigitalkettle Frets: 3324
    I don't want to be the 'you don't wanna do it like that' guy but wouldn't you be better off building some shapes from basic principles?
    I could be wrong: you might want something you can sellotape to the back of the toilet door ;)
    Definition of an inversion is slightly looser than a 'drop' voicing (which is an inversion of a closed voicing):
    https://en.wikipedia.org/wiki/First_inversion
    https://en.wikipedia.org/wiki/Second_inversion
    https://en.wikipedia.org/wiki/Third_inversion
    https://www.jazzguitar.be/blog/drop-2-chords/
    https://www.jazzguitar.be/blog/drop-3-chords-and-inversions/
  • GreatapeGreatape Frets: 3609
    edited July 2022
    Better by far to understand the chord construction, know what all the notes are and start figuring them out methodically.
    Yep, worth knowing a bunch of seventh chord voicings, closed and open etc. Def. Now...apologies if teaching gran to suck eggs but slight tangent:
    For practical playing purposes,  I think there's a lot more mileage in understanding (as you prob do) seventh chord types as slash chords. E.g. C7 = Edim/C, Fmaj7 = Am/F, Dm7 = F/D, etc. So when playing styles that don't call for hammering the low strings, dropping the bass note and just playing Edim instead of C7.
    Then exploring the relationship between other triads (diatonic at first) to the primary chord so you can play more pianistically (conceptually and with more ease and dexterity). E.g.  'All Blues' riff. Conceptually a bit more sophisticated but physically easy and a more musically productive way of organising information in your head.
    Also stays well away from annoying the bassist...and you prob know all those strings 123/234 triad inversions already...
    This also makes playing through changes much easier, because it does away with all that 'scale over chord' daftness.
    On from that, you can look at ninth chords etc. Super -useful to know that Em7b5 is the top of C9 for example....then there's all those R'n'B substitution things like glissando from  Gm-Am on top three strings over C7 alluding to C9 and C13....
    Again, many apologies if restating stuff you already know.
  • PALPAL Frets: 542
    Your making it complicated for yourself ! Learn the notes on your fingerboard & learn three inversions of each chord !
      You already are playing inversion chord shapes ! For example if you play the chord of A at the second fret then if you move
      this shape up to the fifth fret and allow your first finger to barre across the third fret you will now be playing the chord of C
      To play a maj7 chord you just need to flatten the root note by half a step so for the chord G you flatten the G root to G flat.
      For G7 it's a whole step s the root goes from G to F ( Whole step ).
      Chords  say G will have to root G in more than one place you can choose which of these you want to flatten as it will give you
      a different voicing. Hope this helps.
  • vizviz Frets: 10734
    edited July 2022
    Here’s what I do. Instead of CAGED.
    First I think of chords based off the bottom E string. Eg open E chord.
    then I learn the 3 inversions for that shape. So for E (022100), the inversions are:
    476454 (C shaped chord) or 42245x (part of D shaped chord)
    77999x (A shaped chord)
    10 11 999 x (well that’s what I do, I’m sure it’s wrong)
    Then for the A shaped chords, eg A major (x02220) it’s
    x4222x (part of the G shaped chord)
    x77655 (part of the E shaped chord)
    and I can’t remember what I do for the 7th.
    Then obvs there are the minors, which are:
    022000
    32245x
    779987
    and some minors for the A shape too.
    Not really looking for theory lessons or alternative suggestions.
    I just thought someone might have a link to some printable chord charts.
    Soz, yeah.
    Prob worth investing in one of the many jazz chord books. Not expensive.
    At the risk of sounding facetious, they're all here (for C maj7):
  • guitarjack66guitarjack66 Frets: 1892
    Isn't it strange how you can be playing a lot of this stuff without being able to describe what you are actually doing?
    ^ that's all theory is, just the language to describe stuff that exists in reality.
    Typically, theory follows practice though.
