I'm in the last throws of rewiring my 2 humbucker tele with the 4 way switch mod to include the pickups in series and parallel. I've used the same mod on a traditional (2 single coil) tele set-up and it works great, but I'm struggling getting it to work with the humbuckers. They are 2 conductor, so do I need to do a similar mod to the neck humbucker that I had to do with the single coil i.e. adding an additional ground wire for the pickup cover?
Here's the diagram that I'm working to:
https://www.fralinpickups.com/wp-content/uploads/2017/03/Normal-4-way-Switching.png Any help would be much appreciated.
Taking them out, I realised that the bobbins weren't made to take a screwed in pole piece. So I've cut down the bottom part of a couple of old bobbins which did accept screw pole pieces and mounted them under the pickup plate so the screws have got something to screw into. I've also switched out the magnets for an alnico 2 and 4. Finally realised that with all that air inside, they would probably need to be wax potted to stop them being microphonic.That bit was quite successful as I found a big bag of paraffin wax pellets leftover from an old candle making project.
So effectively, I need to ground the cover and the baseplate with a seperate wire?
Assuming were are talking about 2-conductor as in a single centre core and shield like a vintage Gibson pickup, and not like the early DiMarzios which have 2-conductor *plus* shield so you can in fact do both phase and series switching... or like many PRS pickups which have a second core for coil splitting.
This is achieved simply by putting a cap in series with the pickup - a good starting value is .01uF, but you may need to experiment since it depends on the pickup characteristics.
The wiring is very simple - if position 1 is the bridge (bridge pickup to A0), connect A0-A3 and B0-B3 exactly as for a normal Tele, and jumper B4 to B3 with the cap.
Some of the necessary connections are absent.
A0 - bridge pickup
B0 - neck pickup
A1, A2, B2, B3 - all to volume pot
Then connect B4 to B3 with the cap.
B0 - neck pickup
Why? A1, A2, B2 and B3 are all connected to the volume control, not to anything else, nor vice versa.
No.
Sorry, that's my terminology. By A0-A3 and B0-B3 I meant A0, A1, A2, A3, B0, B1, B2 and B3 are connected exactly as in a standard Tele.
Read what I posted again, and make those and only those connections, don't assume extra ones. It's really very simple.
A0 - bridge pickup
B0 - neck pickup
A1, A2, B2, B3 - to volume control
B4 to B3 via cap
1) The OP has not made clear which pickup will be combined with the bass cut capacitor as the fourth switching option.
2) In his written explanations, ICBM usually numbers lever selector switch positions from left to right, as viewed by the player. i.e. 1 = neck, 2 = both, 3 = bridge.
In this case to avoid confusion (not that it helped ) I have followed the switching as shown in barnsleyboy's post - position 1 is bridge pickup.
Now then, she's all wired up, and the .022uF isn't making much of a difference, so I had a quick shwifty around the web and got interested in the Gibson Varitone:
- A 1.5H choke is housed beneath the treble pickup and it fixes the range of the notch.
- Position 1 on the Varitone switch is the bypass.
- Positions 2-6 traditionally cycle through 1000pF, 3000pF, 0.01μF, 0.03μF, and 0.22μF capacitors.
- Each cap is paired with a 10M resistor to avoid “pops” when you’re switching from position to position.
Ok, so I'm not putting a Varitone in the guitar (well at least not yet but would the capacitors used be a good range to try?
My other thought was some kind of trimmer variable capacitor that I could twiddle around with until I get a tone that I like, then leave it alone. A bit like this:
https://uk.farnell.com/vishay/bfc280811229/cap-150v-pp-through-hole/dp/1215709?gclid=CjwKCAjw2rmWBhB4EiwAiJ0mtf3kguBvif0F6BsuPuQYLU9CISqaGE2x82VWQpXWIevVr4k9HemcNBoCnyAQAvD_BwE&mckv=s_dc|pcrid|602272695816|plid||kword||match||slid||product|1215709|pgrid|143146518851|ptaid|aud-1212293608305:pla-301409940178|&CMP=KNC-GUK-SHOPPING-SMEC-Whoops-Remarketing-LowROAS-Test906&gross_price=true
..... but I'm guessing that the sweep range won't really make it viable?
