Am building myself a custom pedal board.
35x17 inches. The biggest pedal being a Helix LT.
What would would be the best choice?
I'll be cutting out some wood underneath the Helix and some of the pedals so save some weight as well as routing out slots for all the cables.
I'm going for two wedge shapes sides and a central wedge with a hole cut in it for cables.
Should I go for a solid floor or just have some struts.
Also best way to mount the top to the sides for easy access? Was thinking of cupboard clips so I could take the top off if I need to rewire.
Electrics: I'm going to have all ins/ours as separate sockets on the side.
The biggest concern is the power plug. I was going to mount a kettle lead socket to the side with a 4 way mounted inside. How do I attach the 4 way to the kettle lead socket? Solder or clips and should I cover with some sort of insulating heat wrap?
