Help with line outs etc
Hi All,
So I have a zoom R16 which is fantastic we will be using this for our demo however when i plug the line outs into it ,it mutes the speaker in the guitars/Bass amps,  I know this is probably basic  howevr I have only ever recorded using moddlers and audio interfaces so recording our jams seems like a lost art.
How do I record the amps whilst also hearing them directly from the amp itsself., ?
Thank you
  • GassageGassage Frets: 31256
    Matt, I'm a Level 4 Coach.
    Lineouts are one of my key foci- especially maul defence. DM me.
  • StrangefanStrangefan Frets: 5844
    James you wonderful man............I don't have a clue what you mean :D:D but I shall assume Cricket??
    Bump up so it'd seen..
    Nothing?
  • MusicwolfMusicwolf Frets: 3726
    edited July 2022
    When you say 'line outs' I assume that we are talking either headphone outs or effects sends on the guitar / bass amps?  If it's the headphone out then inserting a jack will break the signal chain.
    Some more details as to what exactly you are trying to connect to would be useful before suggesting a solution.
  • Winny_PoohWinny_Pooh Frets: 7900
    I assume these are basic amps where you are using a headphone out.
    You'll fix your problem and sound way way better if you buy two audix i5 mics and mic the speakers.
  • Danny1969Danny1969 Frets: 10620
    Generally to record a bass either use the DI out of the amp if it has one or buy a £20 DI box and plug the bass into that then the thru to the amp and the DI out to the recorder.
    You can use the line out / effects send of a modelling amp but you need to make or buy a Y cable, otherwise the signal flow will be broken and you won't be able to monitor through the amp as you are playing.
    Personally I would buy 2 x Behringer XM8500 @ £20 each and just mic the guitar amps up to record.
  • StratavariousStratavarious Frets: 3759
    Yep.. DI the bass.. i use an active DI box with a thru to the amp.
    Mic close on guitar amp will likely sound better than the usual DI outs.
    Thanks guys just what I needed :)
    I'm sure  it's all there dude, the line out from the guitar amp (not headphones but the line out on the back of the amp) into a zoom r16 digital mixer, basically I want to hear the amp not just what's coming out of the digi recorder
    I can't recall ever having come across a line out that mutes the speaker, hence the request for details (make / model etc)
    As per previous posters, if this is a basic line out without speaker emulation then you would be far better off using a budget mic.  My favourite for quick recording is a Behringer B906 (a cheap copy of a Sennheiser e906) which does a reasonable job for c£30.  Bass I normally just DI.
    I think you're right, mic is probably the way to go
