I’m depressed coz I can’t play Master of Puppets
Fucks sake
  • flying_pieflying_pie Frets: 1817
    I can *
    *In short sections only then a break is needed
    No faster than180bpm max
    And let's just forget Kirk's solo for the time being
    Maybe one day...
  • digitalkettledigitalkettle Frets: 3282
    Don't be down, this came up in my feed:
    You need to polish up your down picking ;)
  • gearaddictgearaddict Frets: 895
    Yeah, there’s no way I can do those downstrokes. I can barely manage with alternate picking.
  • CarpeDiemCarpeDiem Frets: 293
    Break it down into chunks, and build up the speed gradually. I struggle to get the down strokes up to tempo for the verses, so I’m doing up and downstrokes at the moment for those parts.
  • I'd be elated personally.
    'Vot eva happened to the Transylvanian Tvist?'
  • fastonebazfastonebaz Frets: 4114
    Start with an easy one like For whom the Bell tolls them work up to it.
    It's fun to play for a bit but ultimately seems a chore. But like Moth into flame.
  • DiscoStuDiscoStu Frets: 5537
    I play Puppets a lot. Like, since it came out. I find it more of a battle to keep up these days but I can still do the downstrokes and palm muting.
    I probably don't play it nearly as clean as I used to but I think my speed is alright.
    There's a good video by Art Of Guitar on YouTube for increasing downstroke speed. I found this approach helps
    Basically the exercise is to use short bursts at increasing tempos. Once you've got that down you can try to work on keeping it going for longer
  • BezzerBezzer Frets: 586
    I wouldn't worry about it too much, neither can Metallica.
    (actually, that's doing a diservice to James, but the rest of 'em can't)
    Follow @flying_pie 's advice, he is wise and will show you the way. Short burst, build the tempo, try not to tense up.  And soon as you tense up it's all over I'm afraid ... or you'll rip the tendons from the bones ...
  • fretmeisterfretmeister Frets: 24470
    I can play the bass part.
    Its a proper relentless bit of hard work too.
    This dude is one of the few on YouTube who gets it right.
    https://youtu.be/4ZsPsFZ0Q_U
    There's a bass part?   ;)
    I'm 52. I don't think I'm going to be getting much faster :(
    I've dabbled with the first riff since the album came out but only tried to really play it recently...which was when I realised I can't.
    Nonsense. Age has nothing to do with it.
    If you set aside regular, focused practice sessions then it will start to pay off. If you spend, say, even only 10-15 mins every day just on downpicking and stick to one or two of the riffs then you'll notice a big improvement within as little as a few weeks.
    The key is to make sure it's a routine that you can stick with and keep going every day
  • octatonicoctatonic Frets: 33812
    It isn't too hard, compared to a lot of modern metal tunes.
    You need the right angle of the pick (see Ben Eller video above), start at half speed (or less), play with a metronome and built it up 5-10 bpm a week.
    In a month or two you will have cracked downstroke riffing.
    If you find it running away from you then you are playing too fast too early.
    Slow it down, get it tight then speed up.
    I agree with @flying_pie and @octatonic Keep working at it and ignore your age. I’ve been working on it for months, and I’ve got faster with practice. Go for it!
    One last thing to mention is another riff that's good to help build up technique is 2 Minutes To Midnight by Iron Maiden.
    It's still fast but not as bad as MOP yet still has the mute-mute-open pattern that MOP uses
  • LebarqueLebarque Frets: 3888
    I could play it as a teen, but haven't really chugged for about 20 years. I'd back myself after a bunch of wrist-strengthening practice I reckon.
  • robertyroberty Frets: 10893
    I started looking at it but it didn't seem worth the effort. Same with Slayer. I can't think of a situation where I would play solidly at that speed. I felt the time would be better used elsewhere
  • SheldersShelders Frets: 22
    I can play it alternate picking but it just doesn't sound the same as all downplayed sadly.
    Just to keep this an echo chamber - it really is just practice. Mark Tremontis advice was just literally just sit and down pick for minutes at a time to build up stamina then increase the tempo. Boring but works.
  • prlgmnrprlgmnr Frets: 3991
    never got in the way of Kirk being in Metallica so I wouldn't worry about it
