I have managed to remove the frets without chipping and have cleaned the slots out.
Using the truss rod, it is possible to get the neck straight and the board fairly even. However, it requires several turns and the truss rod feels very tight at that point. I am worried that keeping the truss rod at that tension is going to be harmful in the long term.
I have refretted bolt-on necks quite successfully in the past, but the binding on this guitar will definitely be a bit more challenging. Fortunately, I'm in no rush to finish the job..
