The guitar itself is a workhouse and studio machine. The two Seymour Duncan humbuckers are perfect for rock, metal and other contemporary styles such as jazz and blues. And the middle single coil provides authentic strat and tele esque tones. The middle pickup is controlled via a volume control so you’re able to blend it in with your humbucker and in addition to this, both humbuckers can be coil tapped.
Here is the overall spec of the guitar.
Machineheads: Framus locking machine heads
Nut: Framus low friction nut
Neck Wood: Ovangkol neck
Fretboard: Tigerstripe Ebony fingerboard
Inlay: Traditional Custom inlays (mother-of-pearl)
Fingerboard Radius: 12"
Scale length: 25.5" (648 mm)
Width Nut: 43 mm / 1.7"
Width 12th fret: 52,5 mm / 2.1"
Fret quantity matrial and size: 22 jumbo frets
Bodywood (Topwood / Backwood): Mahogany body, Arched AAA Flamed Maple top (bookmatched)
Pickups: Original Seymour Duncan pickups: SH-1 (neck) and SH-4 (bridge) with covers
E-Compartment Cover: Easy-Access Cover
Pot layout: 1x Master Volume, 1x Tone and 1 x Single Coil blend control. Both humbuckers are coil tapped.
Switch: Framus 3-way switch and Lead Free switch which routes the signs straight to the output jack.
Bridge System: Tone Pros Tune-o-matic bridge with stop tailpiece
Strap system: Warwick security locks
Construction: Bolt-in
Colour Possibilities Righthand: High Polish Finish
Hardware Colour: Chrome
Weight: 4.3kg
There a couple of small dings on the guitar, however it doesn’t affect the overall playability. It has also had a fret dress from Palfray Guitars in Liverpool.
