At the moment I've got quite a few pedals on my board but have ended up needing about 4 power supplies for it all.
So far I've got -
AKG wireless - (with it's own PSU)
Poly tune mini - (fuel tank junior)
NS2 noise suppressor - (FTJ)
Xotic EP booster - (FTJ)
Joyo vintage overdrive (FTJ)
Wampler pinnacle deluxe (FTJ)
Eventide timefactor - (it's own PSU)
Line 6 M5- (it's own PSU)
Boost pedal - (FTJ)
Basically, which power supply will have enough power to power all of these?
The wireless is 12V but I don't mind about that really as I'm likely to change it soon.
From memory, the original M5 power supply from Line 6 is rated at 500mA but I've run mine off one of the 400mA outputs on the Hot Stone Deluxe without any problems.
The Eventide is high current draw as well, but their website says a maximum draw of 380mA at 12V at start up so you could run that as well.
Without knowing the current draw of the wireless receiver I wouldn't know whether you could run that as well.
Feedback
Dimensions are on here:
http://www.decibel11.com/Hot-Stone-Deluxe-Power-Supply.html
