My only reservation is the extra clean headroom in the VR. I was attracted to the DR for the earlier break up, which is relatively true for the VR, but I think it will be around 3dB to 6dB louder than the DR at the point it starts to break up...
I think it should be possible to fit 6V6s in the Vibrolux if you use sturdy ones like JJs, although it would need an alteration to the bias circuit (not difficult). That should drop the power to no more than the DR - they have very similar voltages - and give a softer breakup due to being a bit mismatched with the 4-ohm load.
The vintage channel early in this video is pretty much exactly what my 68 Custom Princeton sounds like.
