Finishing a Guitar neck. Total Noob question?
Hi guys. I have a rockinger strat maple guitar neck with a maple fretboard. 100% Unfinished. No hardware or nut on it yet. I'd like to apply some kind of finish to it. e.g. some coats of linseed oil or similar would be fine. My question is do I put the same amount of finish on the fretboard as well? How many coats would you recommend giving a neck? I would guess there is no need to apply anything in the tuning peg holes or where the neck will be fixed to the body?
  • RolandRoland Frets: 9128
    There are two reasons to finish a neck. The first is to help the wood remain stable by limiting water uptake and loss as air humidity changes. The second is to help keep it clean.
    I don’t like heavy finishes, so I’d wipe it with three coats of an oil/wax finish. Osmo 3032 is my favourite. If you want a thicker finish then you can add more to the back of the neck.
  • @Roland ok thanks for the info. Should I sand and coat, as I would with a body? Should I leave the heel alone, e.g. anything that will be covered by the body once bolted on?
    I’d do the heel too, otherwise it will shrink and swell as humidity changes.
  • Rainy day project started. So linseed oil would be the WRONG thing to use in this case?
  • pickergpickerg Frets: 30
    edited September 2022
    Slight hijack - I use a bit of tru oil on the back of my bare wood maple neck but was thinking of using wax too.
    Was thinking of the stuff from Monty’s but guessing it’s something that’s just pre-packaged with a markup for the fancy packaging
    Anyone know what that is or what Fender CS or Music Man use on their ‘unfinished’ necks?
    Would that Osmo 3230 be the stuff to try?
    Cheers
  • WezVWezV Frets: 17500
    I like natural bri wax.
    You can find the recipe for the musicman stuff online.  I think its equal parts beeswax and mineral oil.  Briwax is pretty similar to that.
  • paulnb57paulnb57 Frets: 3222
    I use two coats of Tru Oil, seals the wood, silky smooth
    For me the wax is used as well as oil, not instead of
    Thanks, that’s really useful. Had a look online and it does seem Music Man use the gun stock oil then wax, which does look the pretty much the same blend as the bri wax you mentioned. I’ll give that a go this week.
    Cheers, that’s what I’ve been doing, gonna give the wax a go too.
  • FlipFlip Frets: 68
    I prefer the fretboard untreated except for a few drops of D'addario fingerboard conditioner. On the neck I use a very light dressing of boiled linseed oil, nothing else. Gun oil if you wish but boiled linseed oil is less expensive and the finish is beautiful.
  • @Flip I already have the linseed oil so will check out the fretboard conditioner
    Sorry, offlline for a couple of days. I'm sure you'll be happy with the result.
  • @Flip Hopefully. I might do the same to a body I have lying around. (Guitar body that is!) A dark brown stain would be nice.
  • Osmo is good
  • Osmo is good
    Will check it out. Just a few coats?
    Two or three
    I wouldn't use oil on the body. My gut instinct is that even after several rub downs there's a chance that the il will come off on the player's clothes. I prefer to clear coat. I've used acrylic spray and severely thinned wipe on poly successfully though the spray's not as hard work.
  • @Flip good advice thanks. I didn't think about the oil coming off on my clothes.
  • TTonyTTony Frets: 28444
    It doesn't.
    I've oiled many (guitar) bodies, sometimes over stain, sometimes just over the wood.  It doesn't "come off" unless you're picking up the body up when it's still wet!
    Through time, an oil finish will wear, but then so will most finishes.
    If you rubbed it down with olive oil it might come off on your clothes.... but lets assume we are talking about finishing oils rather than cooking ones. ;)
