Black headstock finishing - like vintage juniors ?
Any tips on getting a nice vintage style Black finish on a headstock ?
I have tried grain filler and auto paints before but never been fully happy.
Fuji spray kit should be here in next week or so, so I am trying to go for better approaches from now on.
Any tips ? Either nitro or water lacquer based.
Leaning towards water based as I have a less than ideal set up with the workshop doubling as the laundry room !
cheers
  • Just to rule out the obvious, what material are you painting onto, and what weren't you happy with before?
  • FunkfingersFunkfingers Frets: 15274
    Wot? No black veneer on top of the neck wood?
  • WezVWezV Frets: 17500
    A vintage junior is just black nitro over the mahogany.
    A vintage LP is black nitro over the white holly veneer
  • PeteCPeteC Frets: 500
    onto shellac sealed Mahogany and using auto paint aerosol in satin black
    Too much sinkage into the grain - even after using Rustins grain filler and sanding back lightly with 600 grit twice I still have plenty of small pinholes/grain dips
    Thats after about 8 coats - maybe I am being too light with the spray, trying to avoid any pooling
  • davrosdavros Frets: 1525
    It sounds like you have the right approach, just need more clear coats then a careful wet sand. I recommend nitro as I've never had success with car paints, at least not from Halfords.
    This is a DC junior, just grain fill, sealer, black then clear wet sanded back. This one didn't get a full polish but there is no vusible grain.
    Cheers.   Its getting there now.
  • paulnb57paulnb57 Frets: 3222
    Thats because Halfords paint is rubbish, go to the local place that supplies car painters, they will mix your colour of choice into a rattle can, far, far superior to Halfords, BnQ etc
    You would be amazed how many professional car repairers use rattle cans for small jobs
    I remembered I had a stash of nitro cans from Steve that went into storage when I moved house 18 months ago - and voila - a can of black nitro reappeared.
    All is well!
  • SargeSarge Frets: 2441
    edited October 2022
    For what it's worth, I've found using Superglue as a grainfiller on big open grained woods an exceptional remedy.
    Ash, mahogany and an unknown timber.. possibly limba? all filled beautifully with medium viscosity glue.
    I used kitchen roll cut into small foldable squares, working quickly to cover as much area as possible before it "goes off"
    no shrinkage and levels perfectly.
    A small bowl of water at hand to dispose of the used paper, also a well ventilated area is essential.
    Ta.  Very useful
