Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Screwing pivots directly into pine is asking for trouble. Threaded inserts are little better. String tension eventually compresses the soft wood, allowing the pivot screws to lean towards the neck. Intonation MAY be compromised. Eventually, the pivots tear themselves out.
I’m slightly puzzled as to the point of a non-fine-tuner Floyd though - is the body drilled at all now?
Thanks - Body is currently drilled for six-screw bridge. I have the non-fine tuner on another guitar and like it (locking tuners).
I have the bushes in an alder Kramer 1984, and I had to glue them in with epoxy, wood is wood, it varies, but I think the screws work very well when installed correctly and not adjusted a lot.
Same principle applies with the ABR screws in a vintage spec LP, more direct contact, less moving parts.
