Where can i get inlay material from ?
Im looking for a piece of green abalone/paua abalone (54mm x 24mm x 2mm/1.5mm)
Obviously to find a piece that size in solid shell would be almost impossible.
But i can even find the thick laminate type
Unless you buy a sheet £100 plus
Anybody know where i can source some ?
  • It would be worth contacting Small Wonder, and see if the guy there (whose name I’ve currently forgotten) can provide you with the specific piece you need. I would agree with you that it’ll needed to be a piece of laminate.
  • WezVWezV Frets: 17500
    I dont know if laminated shell comes that thick.  I do have half a sheet of Abalam somewhere which tends to be about 1mm thick
    Smallwonder stuff is really good quality
  • Small Wonder hasn't got any stock of laminate
    In Abalone,or Paua.
  • KalimnaKalimna Frets: 1590
    I have a couple of small sheets abalam, I shall check the thickness and colour for you, if of any interest?
