I think Luminlay are now shipping to the UK again.
If you want to use the powders, you can drill out the existing dot, fill the hole with powder, then add a drop of thin superglue. The other easy way would be to mix the powder with resin, and make a small sheet you punch dots from
Instagram
At about £17 for half a kg of the stuff, it's a hell of a lot cheaper.
If I want them on the guitar I’ll get them pro installed. Just don’t want to commit to mod-img a guitar that may not be a keeper, I’m enjoying gigging the Frankie but I’m pretty sure I’ll want to sell it on at some point.
I was just going to say I'd have thought white would be easier to see, unless you're playing in total darkness.
The polyester film is to protect the base material from washing/wiping damage.
It charges quickly upon exposure to light, but loses luminescence & visibility over a fairly short time, so in darkness isn't too good to see.
I might still have some somewhere, so if you would like it, PM me & I'll send you some.
Personally, I'd look to buy some Super Luminova type powder & mix it with PVA.
I recently installed non-luminous dots in my grandson's guitar using ivory-coloured 1.5mm rod. I found a spring-loaded centre punch invaluable.
