RARITIES FLAME MAPLE TOP HSS STRATOCASTER THINLINE
(12/2019)
USA -- Rarities Collection (Limited Edition)
MODEL NUMBER: 176501833
BODY
Body Material: Mahogany with Flame Maple Top
Body Finish: Gloss Polyurethane
Body Shape: Semi-hollow Stratocaster
NECK
Neck Material: Solid Rosewood
Neck Finish: Hand-Rubbed Satin Urethane
Neck Shape: Modern & "Deep C"
Scale Length: 25.5"; (648 mm)
Fingerboard Material: Rosewood
Fingerboard Radius: 9.5” (241 mm)
Number of Frets: 22
Fret Size: Narrow Tall
Nut Material: Bone
Nut Width: 1.865” (42.8 mm)
Position Inlays: Mother-of-Pearl Dots, Narrow Spacing
Truss Rod: Bi-Flex
Skunk Stripe: Yes
HEADSTOCK
Type: Small
Logo: Large Whitish Spaghetti
Other Decals, front: None
Other Decals, back: None
ELECTRONICS
Bridge Pickup: Custom Double Tap Humbucking
Middle Pickup: Custom Shop '69 Strat Single-Coil Pickup, Staggered Poles
Neck Pickup: Custom Shop '69 Strat Single-Coil Pickup, Staggered Poles
Controls: Master Volume with S-1 Switch, Tone 1. (Neck, Mid), Tone 2. (Bridge)
Switching: 5-Position Blade
S-1 Switch on Volume Control Selects Rear Coil of Bridge Pickup
Configuration: HSS
HARDWARE
Bridge: 2-Point Synchronized Tremolo with Pop-In Tremolo Arm
Saddles: Vintage Style Bent Steel Saddles
Tuning Machines: Fender Standard Cast /Sealed Staggered
String Tree: Ezy Glider
Hardware: Nickel/Chrome
Pickguard: 3-Ply Parchment, 11 Holes (Config. Modern) (p/n 0056799000)
Control Knobs: Aged White
Switch Tip: Aged White
Tremolo Arm Tip: Aged White
Pickup covers: Aged White (Sigle Coil), Uncovered Zebra (Humbucker)
Neck Plate: 4-Bolt, "LIMITED EDITION", "CORONA, CALIFORNIA", Serial "LE"
COLORS
(833) Violin Burst
MISCELLANEOUS:
Strings: .009-.042
ACCESSORIES
Brown Hardshell Case
COMMENTS
Truss Rod Nut: 1/8"; American Series
FENDER SAYS
Combining exotic tonewoods with premium pickups and appointments, the limited-edition Rarities Collection creates a truly unique musical experience.
The Rarities Flametop Stratocaster HSS Thinline features a mahogany body with a Violin Burst flame maple top and solid rosewood neck. The Custom Shop 69 single-coil pickups add a breathy, open note to the traditional Strat voice while the custom Double Tap bridge pickup offers both a sweet humbucking voice and - via an S-1 switch - dynamic single-coil sound.
I have added to this instrument's incredible versatility with the addition of a mini-switch, which allows for neck & bridge and all three pickup together combinations (also known as the 7-switch, or David Gilmour mod). I have done this modification to almost all my Strats. It is simple to do, reversable (just disconnect 2 wires and swap the pickguard), and enables some great extra sounds.
I have owned this since new (bought Aug 2020) and only played it at home (in a pet and smoke-free environment). It is in excellent condition, with zero fretwear, and the full Rosewood neck feels sublime. I'm only selling as I am thinning out my guitar collection, and I have a couple of other Strats which I have owned for many years and have a greater emotional attachment.
![Image: https://i.ebayimg.com/thumbs/images/g/D1wAAOSwq-1jRI2V/s-l225.webp Fender Rarities Flame Maple Top Stratocaster HSS Thinline Semi-Hollow Mahogany](https://i.ebayimg.com/thumbs/images/g/D1wAAOSwq-1jRI2V/s-l225.webp)
![](src)
![](src)
Worth trying eBay if you want a quicker sale. There are some offers on for the next three days - £1 final value fee, or 80% off final value fees.
It used to be very lively but the pace is noticeably slower in General.
Guitars /pedals seem to tick over but amps come here to die at the moment.
There are some very active buyers /sellers on here but ,of late ,a lot of inaction but a million questions.
As my clothes shop owning friend used to say " Come on , Are you buying or Spying ? "
I've seen bargains on Facebook Marketplace sitting for weeks (Some of them are still there), super tricky right now.
Also if I was about to drop almost 2k for a guitar, I would ask everything even how it smells, if you don't answer the question or do it in a way that shows you are irritated by the question (Yep not all HSS sound the same) then people will lose interest.
Cheers and good luck with the sale!
Might also be interested in a part-exchange on a Patrick James Eggle 96 (HH version, as I have a nice HSS already)
