Cheap parlours: are Fender & Gretsch any good
YorkieYorkie Frets: 1554
My Yamaha electroacoustic dreadnought is too big for me. It’s only taken me >20 years to realise, but I’ve got there in the end. I need something smaller. I play and record blues (90% of time it’s clean, the other 10% through a Blues Driver). So I thought a parlour would be a good fit. I am fine with a purely acoustic model, and can’t spend more than £200 at this point anyway.
Are the Fender and Gretsch (Jim Dandy or something like that) models any good at that sub-200 price point?
Many thanks,
Jon
Adopted northerner with Asperger syndrome. I sometimes struggle with empathy and sarcasm – please bear with me.
My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
«13456
  • BillDLBillDL Frets: 7713
    I have a Fender Fender CP-60S Parlour Guitar in sunburst.  (my NGD thread for it) It cost £158 from Gear4Music in June this year.  It's not a whole lot shorter than a standard acoustic given that the 20 fret neck (24.75" scale) joins the body at the 14th fret rather than the more traditional 12th fret, but the body is nice and small so it's pretty easy to lie back on the couch and pick or strum, which is the reason I bought it.  The top is solid spruce and the body and sides are laminated mahogany.  The fretboard and bridge are walnut, and the fretboard feels pretty comfortable after the very slightly rough fret ends were filed smooth.  42.9mm plastic nut and dual-action truss rod.  The tuning gears aren't the greatest quality, but they work OK and hold tune once you get there.
    It is very well made and finished for the money and feels good to play.  It is slightly "boxy" in tone, as can usually be expected for the reduced body volume and soundboard area, but is surprisingly loud.  One thing that improved the sound noticeably was peeling off the cheap plastic scratchplate.
    I don't think the CP-60S is available with a piezo pickup, but I didn't want or need one.  As an easy to play, more portable acoustic guitar for spare time strumming and picking for my own entertainment on the couch it does me fine, but if I was looking for a more serious parlour sized guitar to record or perform with I would be inclined to go for a more expensive and (probably) better one above the £200 level.
  • YorkieYorkie Frets: 1554
    Thanks! I wouldn’t mind spending £200 or more to buy something better second hand, but I haven’t found anything suitable. Will have a look at your NGD thread in a minute.
  • Dave_McDave_Mc Frets: 2390
    edited December 2022
    If you don't mind spending a bit more, you can get Fender Paramount and Recording King (the memorably-named RPS-11-FE3-TBR) all-solid parlours for £300-£350 (new). I haven't tried them, just to be clear- but they might be worth considering. EDIT: oh or there's a Harley Benton all-solid one for around £200 as well- again, I haven't tried it.
  • KittyfriskKittyfrisk Frets: 19351
    Cracked record time  ;)  Try out a Vintage V300MH if you can, as well as the recommended guitars above.
    https://www.thefretboard.co.uk/discussion/227138/nagd-vintage-v300mh/p1
    That's a good call actually. I think I have tried that one (several years ago) or at least something very similar (i.e. still a Vintage at a similar price/spec), and it was very nice indeed!
  • KilgoreKilgore Frets: 8601
    You could have a look at Baton Rouge parlours.
    Caveat: I know nothing about them, I just recently stumbled across them on YouTube.
  • droflufdrofluf Frets: 3888
    Nothing wrong with parlours but you may not need to go all the way down, sizewise. Like you I find Dread’s uncomfortable and am much happier with smaller guitars; for me the “sweet spot” is probably a 00.
    But I’d endorse the recommendation for Vintage as a brand, I’ve got the Paul Brett signature 12 string and it’s a great guitar. And yes it is a parlour :) but my main guitar is a 00.
  • Cracked record time  ;)  Try out a Vintage V300MH if you can, as well as the recommended guitars above.
    I have been looking at these for ages but the narrow fretboard is a killer for me.
  • paulnb57paulnb57 Frets: 3098
    I have a Jim Dandy, I like it, I suppose they have their own sound, but are a great blueser
    Thanks everyone for your suggestions. Always a pleasure to ask questions here.
    Cracked record time
    I pulled an inverse Brian May manoeuvre. I bought the guitar and started a PhD at the same time, but my research career took off almost immediately and so for the past ~25 years the guitar was sitting in a corner in every house, every country and every continent I've worked in. And now I can finally play, I'm getting 25 year-old buyer's remorse. Mental, I know.
    Jon
    ^ Thankfully, there are no rules to owning guitars. Just do it your own way in your own time, that's the right way for you  :)
  • As. A Blues tool my gin Ricky has turned out to be hard to beat. It has that old school blues sound then plu it in with some drive it’s a nice for blues slide, takes tunings fine and had mine coming on 3 years and use it a lot.
    Jon
    Take your time choosing a new guitar. Don't be badgered into a decision you might regret.
  • Kilgore said:
    Jon
    On previous experience patience is something he definitely has!
    Cracked record time
    Jon
    Glad to hear you have put your mis-spent youth in research behind you and come back to the guitar.
    I was tempted by this from thomann, although I ended up buying something more expensive:
  • bertiebertie Frets: 13578
    V300 is  good call for trying a smaller bodied guitar (but no down to parlor size) at a great ££ point  -   personally not a fan of all mahogany not spanky enough  the "warmness" is a bit dull/lifeless for me -  but they do a spruce top one.
    I would definitely try some smaller bodied guitars before you buy,  not all are made or sound equal and can vary massively in tone.  You may not like what you hear so dont play just one
  • I tried a Gretsch Jim Dandy at PMT. It felt and sounded poor to me.
    It was worth going in store to try a few as I'd been interested in the Gretsch for a long time - in the end I played various acoustics and came away with a Yamaha.
    They're very much a one trick pony. I think they sound OK for that rustic country blues vibe but not much else.
  • CleckoClecko Frets: 297
    Totally agree with this. I've had the mahogany V300 for years and I like it loads, but it is quite dark sounding. Mine simply cannot achieve a bright or spanky sound and once the strings have lost a bit of their newness it wouldn't be unfair to say it sounds a touch dull. I'm a big fan of it and think it's a bit of a bargain, but worth trying one out before buying and maybe auditioning alongside a spruce top guitar, depending on your tastes.
    careful, people have been banned (or worse) for agreeing with me on here
