My low E string sounds .... Flubby.
It's all my own fault of course. Self built guitar, sorted the nut myself (I have files for the job).
1 Cause of flubbiness? (in other words it just sounds a bit dead)
2 So something I could maybe fix with bicarb/superglue or new nut required?
I can't get my action low enough.
I've had a few goes at levelling the frets on my various guitars, I always seem to end up with the same problem, Somewhere up the dusty end the high E bottoms out on another fret (9.5 radius), so I end up raising all the strings. I can't seem to get things right either doing all frets in one go or just fixing the one that appears to be the problem. Generally I let it slide as I have always played with a highish action. But then again, every 6 months or so it bugs me that I haven't got it right and I fiddle again. I'm due a fiddle.
This may of course be because the necks I make are inherently squiffy!
Either way - any advice before my latest attempt?
Set the highest and lowest strings first. Adjust the other four strings to the offset radius curve. NOTE: The strings need to follow the arc. The tops of the saddles should remain parallel to the bridge baseplate.
On Stratocaster type guitars, regardless of fingerboard radius, I almost always use 10-46 or 10-48 gauge strings. The clearance between the low E string and the twelfth fret is a gnat's over 2/32nd of an inch (c. 2mm).
This way, the guitar puts up a bit of a fight and the fulcrum vibrato feels right.
Final thought. What material are your bridge saddles? Cast zinc should be expected to sound flubby compared to steel or titanium.
