I know, I know, this has been asked a thousand times. Problem is, I've gone to some of those older pages and half the time the links are broken, and the other half I can't find the products people mention.
I'm after a not-too-expensive soldering iron. Fact is I'm growing tired of spending £40 a pop and a weeks turn around getting a set of pickups swapped in and out of guitars, so think I need to learn how to do it myself.
It wouldn't be used all the time, just for the odd aforementioned pickup swap and/or any wiring repairs that may come up like swapping pots or capacitors every now and then. Probably won't need some massive gas powered fishing rod sized behemoth capable of getting up to a billion degrees or whatever.
I have no idea what a decent one would even cost. There's the ebay/amazon cheapies, there's the more upmarket stuff that costs hundreds of quid. I don't even know what is or isn't really necessary or what end of that spectrum I'd need to look at.
What do people recommend? Is it even worth getting one if it's only going to be used every few months or so?
Just so people are aware. I have no idea what any of these words mean.
For that purpose you can't go far wrong with basic stuff from Weller or Antex - you should be able to get a reasonable kit including a stand for 50 quid or so
It's the ZD-929C model
Like this... Eagle Professional Soldering Station with Temperature Control & Digital Display 5021196043652 | eBay
LF solder is harder to use well and unnecessary for casual home use.
IMHO it's better to stick to old style leaded 60/40 solder - this is what's found in older guitars and amps.
For general use I'd recommend 60/40 (tin/lead) flux core solder in 1.5mm or 1.2mm thickness 180 -190°C Melting Point.
Solder prices have gone up big-time and it can be expensive.
The minimum quantity you want is a 250g roll - a 500g roll will last a while.
https://cpc.farnell.com/duratool/d01683/solder-wire-sn60-pb40-1-2mm-500g/dp/SD01537?st=60%2040%20solder or similar
Soldering Tip Iron Cleaner, Solder Tip Cleaning Wire, Soldering Tip Cleaning Ball and Base, Holder Soft Coiled Brass Tip Cleaner Kit (No Water) : Amazon.co.uk: DIY & Tools
This plus the damp sponge will keep your tip clean - clean and tin regularly.
