HX Stomp has a combined input for 2 additional switches or 2 expressions, or one switch and one expression.
The Helix has separate jacks for each.
The Mission SP1-L6H has 2 outputs, a switch and a standard expression.
Do you want to use the toe switch and the expression? If so you will need an insert cable.
If you just want expression, a standard TS cable should be fine. Just plug it form the expression output into the Stomp.
I have a standard expression pedal (and old volume pedal I modded. I set as volume but use one of the main switches on the Stomp XL to toggle to wah and back when needed. You can do that or configure to use the Missions toes switch to do the same.
So you’re saying if I want to use the toe switch to engage the effect and the wah pedal to control the sweep then I need a Y cable? And the two ends of the Y will go from the two outputs of the pedal, and the stereo end into the HX Stomp?
