Just because its a Strat copy doesn't necessarily mean the parts are Fender compatible, which Guitarbuild bodies are…
So first off Id hold the Rockinger neck alongside a Fender/Squier neck and check they are the same.
Then measure across the heel at the widest part and see if its 56/56.5mm. Check its the same height front to back too, Is the nut in the same place relative to the heel on both necks?
Note that the heel end of a Strat neck has a slight radius, a Tele neck is square, fitting Strat to Tele or Vise Verse, there will be a slight mismatch, if that doesnt bother you then fine, but worth knowing, there are ways around it, you could mod the end of the neck, or mod the scratchplate
Assuming the neck is physically the same as Fender spec, then I dont see an issue and a Tele bridge should work
If you need a photo of the neck mismatch, Ive got enough parts littering the place to oblige….
Apologies if you already knew this, I learnt the hard way!
I will get out the measuring tape later !
Just need to check how a strat neck works with tele spacing etc...
If I were to go HH config should the hardtail bridge have SC or TC spacing…
Bandcamp
