Spin-off from the previous thread about skipping the first track.
Inspired by ABBA's Arrival - where the title track is bizarrely the closer when it should be the opener, and the opener is (at best) Side 2 filler - albums where all the songs are good, and the album would be great, but is incomprehensibly spoiled by a terrible running order. It really can make a huge difference.
An even better example - The Beatles' Let It Be. I honestly think the album would have been far better received if it had been sequenced correctly - at the very least, Get Back should be the first track and The Long And Winding Road the last... you can probably argue over the placement of most of the ones in the middle.
The third disc of George Harrison's All Things Must Pass is another one - notoriously only listened to once by most owners, because it's a disjointed mess. But not if you put it in the correct originally-intended order, which is on the remastered version. (Johnny's Birthday, Plug Me In, Jeep, Pepperoni, Out Of The Blue.)
Or any number of albums where the best tracks are all on Side 1 and no-one bothers listening to the other side.
Over to you
![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
But that’s just my 2p.
Let It Be is still the best example I can think of - even the 'Naked' version, which does start with Get Back, isn't right since it doesn't end with TLAWR.
Whereas Abbey Road is truly great, not only because it has great songs - although not *that* much better, in my opinion (and many were written at the same time as Let It Be, as becomes obvious from the restored Get Back film) but because the running order is perfect.
2. Hey Honey – I'm Packin' You In!
3. Can't Stop This Thing We Started
6. Vanishing - slow and soft
7. House Arrest - hard and fast
8. Do I Have to Say the Words? - slow and soft
9. There Will Never Be Another Tonight - hard and fast
10. All I Want Is You - slow and soft
11. Depend on Me - slowish and soft
12. (Everything I Do) I Do It for You - slow and soft
13. If You Wanna Leave Me (Can I Come Too?) - hard and fast
14. Touch the Hand - hard and fast
15. Don't Drop That Bomb on Me - hard and fast
Just because there’s space to fit 74 minutes of music on a CD doesn’t mean you should... thankfully I rarely listen to the CD directly these days, I almost always use iTunes so I can delete the junk and change the order if I want to.
Bon Jovi - Slippery When Wet. All the good tracks, including the band's three best-known songs and live staples, are on side one. Side two is dross. I always used to say I liked Bon Jovi for their first two and a half albums (now I don't really like them at all).
Black Sabbath - 13. Every time I listened to this album I'd enjoy the first few tracks then lose interest (or fall asleep) long before the end. I found the only way around it was to play the album on shuffle, to add an element of surprise.**
(** This approach also helps with most of the recent Metallica albums. Although it doesn't help enough.)
Revolution Come, Revolution Go by Govt Mule is the first that comes to mind . Not a bad album in its single-disc form, but the first two bonus songs definitely deserve a place on the main disc.
There is a lot more pressure to produce that now, but 40 years ago most albums were 2 or 3 hits and the rest was filler and if it reached the mighty heights of 4 hit singles, then the album was a classic.
