SOLD Charvel Pro-Mod DK24 HSS 2PT CM Ash. £500 posted
Up for grabs is my Charvel Pro-Mod.
It’s a lovely thing that plays great. A couple of things to mention. I’ve installed a trem block in the back and replaced the trem springs for raw vintage springs. So in effect the trem is down only, you can’t pull back on it. I can’t deal with floating trems hence why it was done.
It’s easily reversible. Just unscrew the trem blocker and balance the tension to get the trem floating again.
Condition wise it’s excellent I can‘t see any obvious dinks or dents, which is pretty remarkable considering the unfinished body.
I’m moving this on as it’s covering a lot of similar ground to my Yamaha 611.
It will come with a tweed Fender gigbag. Trem arm and back plate included.
I can post this as I have boxes ready to go.
Price is £500 inc postage.
Full spec below:
Specifications
Body
- Body Shape: Dinky
- Body Material: Ash
- Body Finish: Satin
Neck
- Neck Material: Caramelized Maple
- Neck Construction: Bolt-On with Graphite Reinforcement
- Neck Finish: Satin
- Fingerboard: Caramelized Maple, 12”-16” Compound Radius (304.8 mm to 406.4 mm)
- Frets: 24, Jumbo
- Position Inlays: 4mm Pearloid Dot
- Nut (Material/Width): Graph Tech TUSQ XL, 1.6875” (42.86 mm)
- Headstock: Licensed Fender Stratocaster
- Tuning Machines: Charvel-Branded Die-Cast Locking
- Scale Length: 25.5” (648 mm)
- Truss Rod: Heel-Mount Truss Rod Adjustment Wheel
Hardware & Electronics
- Bridge: Gotoh Custom 510 Tremolo
- Bridge Pickup: Seymour Duncan Custom Full Shred SH-10B
- Middle Pickup: Seymour Duncan Custom Flat Strat SSL-6 Single-Coil
- Neck Pickup: Seymour Duncan Custom Flat Strat SSL-6 RWRP Single-Coil
- Pickup Switching: 5-Position Blade: Position 1. Full Bridge Pickup, Position 2. Bridge Inner Coil and Middle Pickup, Position 3. Bridge Outer Coil and Neck Pickup, Position 4. Middle and Neck Pickup, Position 5. Full Neck Pickup
- Controls: Volume, Tone
- Control Knobs: Stratocaster-Style Skirt
- Hardware Finish: Chrome
- Strings: Nickel Plated Steel (.009-.042 Gauges)
Pics:
