We live in a 60s built dormer, daughters bedroom is in an exposed corner and the wall on the dormer has been freezing cold this winter which has led to condensation running down the wall, horrible black mould all around the radiator and under her window. I couldn't insulate the boards from outside as I can access the void. However I could see that there wasn't any wetness in the outside if the wall boards by removing a vent and putting my hand inside to void.
Anyhoo, got some insulated paper from Toolstation, it's fleece backed and very thick (and a bastard to work with, you needed very sharp blade for cutting)
Was not cheap at £60 a roll and a further £20 for the special ready mixed adhesive which is like thick custard, luckily only required one roll though. This was tipped off with Zinsser Mould Proof Emulsion
First thing noted was how much warmer the wall is even when it's been minus °C outside.
Not a hint if condensation in the two weeks since it has been done.
Thought id put this out there as the theme of condensation seems to pop up from time to time.
"OUR TOSSPOT"
I was told that wasn't enough and I should have gone with something thicker, but it was the warmest and driest room in the house afterwards
Instagram
It's quite normal to wake up and have to vacuum her window free of condensation with a Kartcher window vac. The window reveal and ceiling above the window also condense quite badly if it's cold outside.
I've been running a dehumidifier this winter which seems to have made absolutely no difference at all to condensation in the house!
I might give that insulated paper a look, do have a link to the products used, @jonnyburgo?
Also, while were on the topic, is there a product I could apply to the ceiling to do an equivalent job on that surface? I'd quite happily lose a bit of headroom if I could make the room warmer and less prone to condensation forming.
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
Having our bathrooms done soon.
Condensation is extremely difficult to eradicate
ventilation or de-humidifier is the next key
In a 1960's build with a dormer there's a good chance that there's no insulation at all on the dormer.
If there's space you can add it internally though you'll need to ensure there's airflow round the timbers for the dormer or it can rot from the inside out
Alternatively you can add external insulation although that may require alteration to the roofline of the dormer and is likely to be a bigger job. If the windows are more than about 15 years old I'd replace them at the same time
