Hey all
Swapped out the pups on my Silver Sky SE to a set of bare knuckle mothers milks and having some issues.
When I first installed it the neck pickup position only wasn’t grounded.
pulled it out, checked all the solder joints and made sure nothing was shorting and there were no obvious issues.
Reinstalled and this time no buzz but all 5 switch positions sounded exactly the same (Like number 2 or 4)
Pulled it out, checked everything again, replaced the switch with a spare I had and now have the same problem.
Any thoughts? Will get some pic up shortly
thanks
https://i.imgur.com/spCcRnR.jpg
https://i.imgur.com/iiQyHHH.jpg
Possibly of greater significance, you have mounted the selector switch the wrong way around. It is wiser to have the terminals on the open side facing towards the pots. The way that you have it, the terminals could be touching any screening materials on the routed cavity wall or physical pressure could be distorting the switch, affecting which connections are made and/or interrupted.
thanks guys, will report back
sounds awesome with the BK mothers milk pups.
cheers all
