You could then replace the Lithium pickups w/ Holdsworths and you won't be a million miles away IMO.
Vader tuners/trem bang into your leg and push the guitar out of tune.
Vader is not well balanced compared to the Holdsworth models.
Holdsworth's come with 20" radius as standard and a particular neck carve. My Vader was 12" from memory and a neck like a bat which I didn't like (although different ones will have different options). Holdsworths are usually chambered, the Vader isn't.
That's my thoughts on the matter anyhow.
Imo.....get a Holdsworth if you can find one.
So does the Vader. What sort of rubbish are you talking, man? Vaders come 20" as standard, 14" as an option. Both guitars have the same neck thickness.
From their website:
Holdsworth - 1.69" Wide @ Nut, 0.76" Thick @ 1st Fret, 0.88" Thick @ 12th Fret
For god's sake please do a couple of minutes of Googling before spreading misinformation.
Pipe down if you can't be polite, if you want to pick an argument then fine, DM me don't do it on this thread.
I'm a left leg player, classical position. The tuners/trem hit the right leg and knock it out of tune, usually a fair amount sharp. It doesn't happen with the Holdsworths, it's the poor design of the Vader that causes it, and it's insurmountable if you play like that. If you'd owned them both and were a left leg player you'd know. You haven't or you aren't, so you don't know, end of.
The ones I have absolutely do not have the same neck thickness as the Vader I owned.....where did you fail to read that I've had two HH for years and I owned a Vader. One of my HH is the 'thinner' neck profile and the other is standard. Neither is anything like the Vader I had which I really did not like tbh. Not 'played both' not 'once sniffed one in a bar' I have owned these and I know the feel and shape of my Holdsworths extremely well. The Vader I had was way different and I didn't like it at all, which was such a disappointment. Mine might have been a different custom order as Kiesel is effectively a custom shop and all the guitars are different, and I guess these could have changed over the years as this was a 1st year model, but it was very different, in a negative way. Notice I said 'for me' and talked about my personal experience and opinion, I didn't make a subjective declaration about all Vaders apart from on the chambering, balance, and design re: going of of tune if you're a left leg player.
Apologies to OP for continuing on this thread. I won't reply on here again if there's another comment about this.
Again, Carlos, just watch how you talk to people please.
I kept a headless Kiesel Leia, which was more versatile with 2 humbuckers than the single hum Holdsworth I had.
I still have the Leia, phenomenal piece, but wouldn't mind selling it tbh
That is the one I got offered and declined but then grew on me!
https://www.thefretboard.co.uk/discussion/243282/fs-strandberg-boden-masvidalien-ebony-fretboard#latest
Buying kiesels second hand can be a bit of a minefield, as you can spec them very differently, and Kiesel themselves don’t keep the spec or are un interested in telling you it. A holdsworth spec Kiesel from their website is now $2600! They charge you $100 to delete the neck pickup !
https://www.kieselguitars.com/in-stock/161998
Sent them an email as the specs sheet does not match the picture. See what happens!
Thanks for keeping me in mind!
A guy in New york won't sell me his
Disgusting 12" radius, though! But very classy finish.
