Sold: Martin 000X1AE £325
robt1291robt1291 Frets: 82
edited March 2023 in Acoustics £
Hi all,
Martin 000X1AE (With a gig bag) - Made In Mexico
Price: £325 Paypal/BACS/Cash on collection
Shipping: £15
Trades: No thanks But you never know
The bad bits:
  • There is a crack in the middle of the body - It doesn't effect playability at all. Not sure on how repairable or un repairable this is. But it plays absolutely fine and for the money you can't go wrong. Hence what I feel to be a reasonable £325.
  • There is also a mark on the body which i have pictured below.
Martin 000-X1AE Technical Specs
General Overview
  • Body Size: 000-14 Fret
  • Finish Top: Hand Rubbed
  • Construction: Mortise & Tenon Neck Joint
  • Bracing Pattern: X Brace
  • Scale Length: 25.4
  • Brace Shape: Non-Scalloped
  • Fingerboard Width At Nut: 1 3/4
  • Top Material: Sitka Spruce
  • Neck Shape: Performing Artist
  • Back Material: HPL
  • Neck Taper: High Performance Taper
  • Side Material: HPL
  • Electronics: Fishman Sonitone
Top
  • Top Color: Clear
  • Bridge Style: Modern Belly - Drop in Saddle
  • Bridge String Spacing: 2-5/32
  • Bridge Material: FSC Certified Richlite
  • Bridge Pin Material: White Plastic
  • Pickguard: Faux Tortoise
  • Bridge Pin Dots: Black Plastic
  • Saddle: Compensated White Tusq
  • Rosette: Multi-Stripe
  • Saddle Radius: 16
Body
  • Brace Material: Sitka Spruce
  • Brace Size: 5/16 With 1/4 Tone Bars
  • Back Detail: Mahogany Pattern
  • Heelcap: Black
  • Side Detail: Mahogany Pattern
Neck
  • Neck Material: Rust Birch Laminate
  • Fingerboard Material: FSC Certified Richlite
  • Finish Neck: Hand Rubbed
  • Fingerboard Width At 12th Fret: 2 1/8
  • Fingerboard Inlay Style: Dots
  • Number Of Frets Total: 20
  • Fingerboard Inlay Material: White Plastic
  • Neck Joins Body At: 14th Fret
  • Side Dots: White
  • Recommended Strings: SP Acoustic 92/8 Phosphor Bronze Light (MSP4100)
Headstock
  • Headstock Shape: Solid with Standard Taper
  • Tuning Machines: Chrome Enclosed Gear
  • Headplate Material: HPL
  • Knob: Small
  • Headplate Logo Style: Script Ink
  • Nut Material: White Corian
https://imgur.com/ICizKOq
https://imgur.com/i6f1qU5
https://imgur.com/TU6fybO
https://imgur.com/d2xdiSm
https://imgur.com/WxUmqqz
