Hello
I'm thinking of putting together my first partscaster Strat.
The body will probably be a Strat Deluxe model as these are readily available direct from Fender. The neck would be a 42.86mm nut width.
Looking at bridge options, I want to ensure I get the correct string spacing. So how do you know what the correct spacing is and also how do you measure string spacing on an existing guitar? Would you use a ruler and measure middle of string to middle of string or calipers and measure the outside of one string to the outside of another?
Thanks for your help and advice.
