This is the 2nd one of these I’ve owned in quick succession. But alas I’m moving this on due to a recent purchase of a PRS DGT SE.
The Charvel plays great and is setup with 9-42 strings. Superb build quality and excellent versatile sounds.
There is a trem stopper fitted in the term cavity (not by me) and 2 Gotoh high tension springs. So it’s dive only on trem. It stays in tune great.
This one has a few battle scars which is inevitable with the unfinished body. The worst of these scars can be seen in the front. You can take it on a gig and not be too concerned about it taking a dink or dent.
Because of this I’m moving this on cheap. I’m basically looking to recoup what I paid for it.
It will come with a gig bag and be well packed. I’ll even throw a couple of sets of strings in.
£400 inc postage.
Model Name: Pro-Mod DK24 HSS 2PT CM Ash, Caramelized Maple Fingerboard, Red Ash
Model #:
2969413539Body: Ash Satin Finish
Neck Material: Caramelized Maple Satin Finish
Neck Shape: Speed Neck with Rolled Fingerboard Edges
Fingerboard: Caramelized Maple
Fingerboard Radius: 12"-16" Compound Radius (304.8 mm to 406.4 mm)
Number of Frets: 24
Frets Size: Jumbo
Bridge Pickup: Seymour Duncan® Custom Full Shred™ SH-10B
Middle Pickup: Custom Seymour Duncan® Flat Strat® SSL-6 Single-Coil
Neck Pickup: Custom Seymour Duncan® Flat Strat® SSL-6 RWRP Single-Coil
Controls: Volume (500K EVH® Bourns® Low Friction Pot), No-Load Tone
Pickup Switching 5-Position Blade: Position 1. Full Bridge Pickup, Position 2. Bridge Inner Coil and Middle Pickup, Position 3. Bridge Outer Coil and Neck Pickup, Position 4. Middle and Neck Pickup, Position 5. Full Neck
Bridge: Gotoh® Custom 510 Tremolo
Tuning Machines: Charvel-Branded Die-Cast Locking
Strings: Nickel Plated Steel (.009-.042 Gauges)
Unique Features: Luminlay Side Dots
![](https://i.imgur.com/suJxXNm.jpeg)
