x2 Alto TS215 Speakers - £450 the pair, no postage, may delivery locally
Both perfectly working but tatty from gigs and being loaded/unloaded etc
- 550W continuous, 1100W peak Class D power
- 15-inch LF driver, 2.5-inch high-temperature voice coil
- 1-inch neodymium HF driver with precision waveguide
- Bi-amplified design with precision active crossover and EQ
- Integrated 2-channel mixer with dual XLR 1/4-inch combo mic/line inputs and independent level controls
- XLR Link output
- Ground-Lift switch
- Contour switch for increased EQ control
- Electronic clip, thermal and transducer overdrive protection
- Compact, lightweight, trapezoidal cabinet design for easy transport and installation
- Can be used as main PA speaker or in floor monitor application
- Stand and pole-mountable with integral M10 suspension points
- Designed and tuned in the USA
- Output Power 1100 W peak (700 LF + 400 HF)
- 550 W continuous RMS (350 LF + 200 HF)
- Low Frequency 15” (381 mm) woofer, 2” (51 mm) voice coil
- High Frequency 1” (25 mm) neodymium driver
- Crossover 2 kHz
- Maximum SPL 129 dB peak, 126 dB continuous (dB-SPL @ 1 m)
- Frequency Response 50 Hz – 20 kHz (+ 3 dB)
- Frequency Range 43 Hz – 22 kHz (-10 dB)
- Coverage 80°/100° H x 60° V nominal
- Connectors (2) 1/4” (6.35 mm) TRS or XLR inputs
- (1) XLR link output
- Cabinet Trapezoidal, injection-molded, polypropylene enclosure, with perforated steel grille
- Controls Volume, power on/off with LED, clip limiter with LED, ground lift
- Protection Electronic clip, thermal and transducer overdrive protection
- Power AC Input: 100–120/220–240 V, 50/60 Hz
- Fuse: 100-120 V T6.3AL AC250V / 220-240 V T3.15AL AC250V
- Dimensions
- (width x depth x height)
- 15.60” x 14.04” x 25.68”
- 396 x 357 x 652 mm
- Weight 32.72 lbs.
- 14.84 kg
https://i.imgur.com/FAkyhi1.jpghttps://i.imgur.com/PbD4OLF.jpghttps://i.imgur.com/NsNudxO.jpghttps://i.imgur.com/f2NlttY.jpghttps://i.imgur.com/92q2KZs.jpg
