FS: Mono gig bag stealth electric M80-STEG - Black
Treewig1Treewig1 Frets: 445
edited April 2023 in Guitars £
As Mono say:
Despite no visible front pockets, the Stealth Electric Guitar Case comes with ample storage options. Seeking inspiration from its name, the pockets lined on the side of the case instead are every minimalist’s ambition. There will be a pocket specifically for your laptop, and two accompanying hidden pockets for your valuables within easy reach.
Using only high-test materials with extreme resistance to abrasion and the elements, the Stealth Electric Guitar Case makes sure your treasured guitars stay protected. Inside, the plush lining protects delicate custom finishes. Outside, the water-resistant shell keeps you on the move, rain or shine.
Good condition.  The only significant mark I can see is on the front (see last shot).
DIMENSIONS & FITTING
Internal Dimensions: 42" x 15" x 2" (106.7cm x 38.1cm x. 5.1cm)
External Dimensions: 45" x 18" x 4.7" (114.3cm x 45.7cm x 11.9cm)
External Pocket Dimensions: 17" x 15" x 1" (43.2cm x 38.1cm x 2.54cm)
Weight: 3.3lbs (1.5kg)
https://i.imgur.com/51LjPSK.jpg
https://i.imgur.com/iRc8VYT.jpg
https://i.imgur.com/XgJT0jT.jpg
https://i.imgur.com/W3bgBab.jpg
https://i.imgur.com/SfLfC5c.jpg
£80.00
