This is something I am sure I haven't had before with a guitar, or perhaps I just haven't noticed it until now. I have a SSS Strat copy I haven't played for a while that, when plugged into my Boss Dual Cube LX, makes a "static" crackle through the amp each time my finger makes contact with any and all of the metal parts including strings, and gets louder the higher the amp is turned up. The guitar is actually quite a quiet one despite being unshielded, but does have the expected low level single coil hum that almost goes away when I touch metal parts. That's quite normal though?
I haven't tested all my guitars through this amp, but so far:
1. This is the only guitar I have that crackles like this with that same amp.
2. This guitar does not do the same when plugged into a directly mains powered amp.
3. I have swapped cables just in case that is a contributory factor.
4. I haven't yet tried the amp with batteries as I don't have 8 x AA ones in the house right now.
5. I tested the power supply adapter with the amp on a different circuit and different sockets in the house and it makes no difference.
I'm using the supplied Roland 9v inline "brick" type power supply adapter with detachable 3-pin supply lead. I haven't tried the amp with other power supplies yet, but I have tested the supplied power supply with a Boss Katana Mini and the guitar doesn't crackle when played through it. The only other portable amp I have that use a power supply adapter is a Bogner Ecstacy Mini Amp Head (24v adapter), and that doesn't exhibit the same behaviour with this amp. I think this was the first time I have played this guitar through the dual cube amp since I bought the amp.
I'll do some more exhaustive testing for elimination later (while I also troubleshoot a Levinson Blade with an odd earthing issue where the hum increases when I touch the bridge and strings but not the other metal parts), but I was curious to know whether anybody else had experienced this effect with any guitars and amps.
The static noise is probably just a consequence of lack of shielding combined with a non-earthed amp.
Saves ages cleaning up though...
