Now I'd have thought I knew how to put a string on a guitar. I've been doing it for 50 years now and reckon I've nearly got the hang of it.
And I know that with round core strings you have to fit them and bring them up to tension before you cut them. (Hell, I do this anyway, with any string, out of lifelong habit.)
And in recent times I've gone overboard and even taken to putting a right-angle bend in the string with pliers before cutting, just in case.
But despite doing everything properly as-per-spec I'm still getting too many round core strings going bad on me.
I've never been one to wind more than the minimum necessary number of turns on the peghead, enough so that it holds pitch, any more than that is just a waste of time. Is this the problem?
What else can I do?
(Apart, of course, from not using round core strings. Which, come to think of it, wouldn't be so hard. There are lots of round cores which are superior to the average mass-produced hex core string (Elixir, Ball, D'Addario, Fender), but then, in my string adventures over the last few years I've found several hex core strings which play every bit as nicely as the better round cores - Galli LS, Phillipe Bousett Acoustique, Santa Cruz, Adamas Composite, to name a few -so simply forgetting about round cores isn't out of the question.)
Anyway, what tips does the Fretboard brains trust have for me?
String through the post, pull back for slack, take the excess round the post (clockwise E A D, anti the rest), under itself and pull up, so that as you wind, the excess is trapped against the post. Then cut level.with the post top.
I don't find any problem with Newtones doing that. (Or with any strings, not just these.)
The extra bend has two benefits, if the string slides through the capstan it will “catch” on the redundant bend. It also stops any unwind of the wrap.
I’m trying to remember the last time I had an issue with a string wind/capstan issue, it must be decades and I gig regularly with multiple guitars.
