I'm a bit hazy on tone pot wiring- the way you've wired it may well work perfectly fine, but I usually connect the wire from the volume to the tone pot to the tone pot's middle lug and then the tone cap from the tone pot's end lug (where the green wire is currently connected at the tone pot) to ground.
Or more simply... you don't seem to have your volume pot grounded. You need to have the unused lug of the volume pot grounded. I actually noticed that last, again that may solve it by itself- definitely try that first (unless you just accidentally left it off your diagram). That is one thing I'm sure of- that needs to be done if it hasn't been already.
Vol. Terminal 1 = Pickup signal and connection to tone control
Vol. Terminal 2 = Output to jack socket.
Vol. Terminal 3 = Ground to pot chassis (and output socket)
Tone Terminal 1 = unused
Tone Terminal 2 = signal input
Tone Terminal 3 = capacitor (other end to ground)
Steve spotted the problem.
All I did was write things out in a way so idiot-proof that even I could understand it.
