Is this a modal progression? Edit, it isn't.
allenallen Frets: 714
edited July 2023 in Theory
I have been dabbling with transcribing again.
I love this song...
So I sat down to transcribe it this evening.
I worked out that there's an F repeated a lot in the intro so I wrote down the chords from the key of F on my little piece of paper.
F Gm Am B C Dm
I then had a bit more of a listen and got about 80% of it. I must admit the harmony sounded a bit 'clever' to me, but not quite sure what is going on. I suspect some interesting inversions over each chord.
Anyhow, there was one chord that was flummoxing me and then I realised it was Bb so it's a flat 4 chord in the middle there in the chorus and pre-chorus.
Does this make it modal? and if so which mode would it be? Or perhaps it's just a flat 4 thrown in as you don't always have to follow rules right?
  • vizviz Frets: 10720
    edited July 2023
    The Bb chord IS simply the 4 chord of F. It’s not a flat 4, it’s just a 4. Which is why F and Bb share a fret, the first fret.
    So where you’ve wrfitten B in your chord list, there isn’t a B, there’s a Bb, which is perfectly normal.
    Don’t know if this helps but if you were to put a capo on the first fret, you’d play the following shaped chords and it’d sound identical:
    E F#m G#m A B C#m.
    The A-shaped chord would be the 4 chord.
    Perfectly understandable, especially in the key of F where only one note has a flat sign, it definitely stands out and looks special.
