Qsc Cp8 full range active 1000w speakers Great condition. Sounds superb whether as PA, Monitor, FRFR for guitar effects processor etc Comes with covers (Not fitted but does the job) and Power leads The CP8 Loudspeaker The CP Series are compact powered loudspeakers offering a 1000-watt, Class-D amplifier. Designed to give you the power that you need to fill a room with these loudspeakers, while still retaining the dynamics at those loud volumes. With an 8” tweeter, it’s ideal for solo performers and small venues. State of the Art Technology for the best sound QSC CP Series loudspeakers are designed to give you clarity. The QSC Directivity Matched Transition® (DMT) design projects your band’s sound comfortably in any environment and for the entire audience. The speakers deliver accurately any signal going through them – from the detailed nuances of vocals or the crispness of cymbals, to the full body of a guitar or a bass sound. The loudspeakers also use Intrinsic Correction; this runs in the background processing the average of thousands of spatial loudspeaker measurements mapped to the internal processor of the loudspeaker to give a smooth and accurate sound across the loudspeaker’s playback. The CP Series also feature on-board DSP (Digital Signal Processing), allowing you to switch pre-selected settings to suit what you’re using the loudspeaker so you the best sound possible. This makes it ideal for bands, DJs and even for use as a floor monitor. It is incredibly easy to find the right setting for your application and get back to it when you need to. The Build QSC loudspeakers are compact, lightweight, and built to last, and the CP Series is no exception. They’re built to be hardwearing and are backed up by the impressive QSC 6-year warranty when you register your products with them. PA Systems If you’re looking for a PA system ready to go, we’ve put together a selection of PA Systems to suit your individual needs. Alternatively, if you need to put something more tailored together feel free to get in touch, we’d be happy to help! Specifications: Configuration: Two-Way Active Low Frequency Driver: 8'' Cone Woofer High Frequency Driver: 1.4'' Compression Frequency Response: 56Hz - 20kHz, -6dB / 53Hz - 20kHz, -10dB Sound Pressure Level: 124dB (Maximum) Nominal Coverage: 90° Axisymetric Amplifier Type: Class-D Amplifier Power: 1000W (Peak) Input Connectors: 2 x XLR/TRS Combo (Line and Mic/Line), 1 x 3.5mm TRS Stereo Output Connector: 1 x XLR (Mix) Controls: Power, 2 x Gain, Mic Boost Push Switch, 6-Way Contour Selection Switch Indicators: Power LED, 2 x Input Signal LEDs, Input B MIC Selected LED, Limiter Active LED Power Supply: 100V - 240V, 50Hz/60Hz Enclosure Material: Polypropylene Grille: 18 Gauge Powder Coated Steel Dimensions: 411mm x 273mm x 256mm / 16.2'' x 10.7'' x 10.1'' (H x W x D) Weight: 11.4kg / 25.5lbs Proel PA Speaker Stands. Solid quality reliable stands. Extend from 47 to 74 inches height ( to bottom of speakers) Some scuffs and marks but cosmetic only and of no consequence to strength or use of stands. |
