I've recently done some work on a Musicman 112 RP-65 combo (mostly a recap) and only outstanding issue is that the Volume control goes from off to full volume between 0-4 and doesn't do much between 4-10.
This is the circuit fragment:
I strongly suspect a log pot would sort this out, but I'm struggling to find one.
The original is a CTS solid shaft, like this:
The only similar 25k Log solid shaft pots I can find are Bourns, and the only place I can find them is Mouser, but they have a £14.40 shipping charge for orders under £33.
Does anyone know of an alternative source?
Thanks,
R.
R.
Eqd Speaker Cranker clone
However... given that they're both CTS of the same era, it's very likely to be possible to take apart both pots and replace the trackboard on yours with mine, so making yours into the correct Log pot .
If that sounds good, I'll send it!
I'll DM you.
R.
