Decent Soldering station
Continuing the motion from my previous 2 posts, Im now looking for a decent soldering iron/ station to use with guitar electronics. I can use a soldering iron well but just teturned from Canada after 10 years and am a little overwhelmed with what is on offer her
Could anyone recommend a decent, cost effective (ie not expensive) soldering iron, preferably with accessories and a station to mount it in?
Cheers,
Jim
  • Devil#20Devil#20 Frets: 2136
    Hakko FX-888D but I don't know what you mean by not expensive. It's a brilliant soldering station though. I bet a few people on here use one.
    Ian
  • FunkfingersFunkfingers Frets: 15276
    Probably worth asking the Fretboard's amp and pedal builders what they use. Precise temperature control can be the difference between a fried component and a working project.
  • RiftAmpsRiftAmps Frets: 3287
    Dave8 said:
    I have two of these at the workshop, alongside two higher-spec ones. They're absolutely brilliant for anything guitar-related if you swap to a chisel tip. Use the fine tip for PCB work.
    No need to spend £££ on high-end fancy shit when these workhorses perform just as well.
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
    RiftAmps said:
    Can that handle the temperatures required for fitting/removing metal pickup covers?
  • SporkySporky Frets: 30210
    Pickup covers (and pot back, which you shouldn't solder to but no-one listens) aren't about higher temperatures, they're about transferring more energy without the temperature dropping. High wattage, tip the size of a shovel.
    Too much information.
    Stop worrying and dithering, get a Hakko FX-888D and you'll forget the cost after the first two or three jobs. Don't buy a cheap knock-off one on eBay, go to a proper supplier.
  • guitarfishbayguitarfishbay Frets: 7974
    I have the Hakko and am happy with it
  • mudslide73mudslide73 Frets: 3131
    What do you all use as your 3rd hand? Most of my soldering crapness comes from not being able to hold everything steady.
  • Danny1969Danny1969 Frets: 11014
    To make cables drill a 6.5m hole in a lump of 4 x 12 and shove the jack in to solder it. Drill the hole on the side of the wood for straight jacks and on top of the wood for patch cables / right angled jacks
    For small objects get a large lump of bluetack and press the component into it, then solder.
    My pick for a soldering station is the Weller 24V range. I solder everything from SM TQFP chips to large conductors used for high current TRIAC switching and it never lets me down. Been going over 20 years now with one repair to the cable which I covered in our community repair thread
    Blu Tac is your friend. Doesn't wick away the heat so quickly so makes soldering quicker which is what you want.
    Ian
  • thermionicthermionic Frets: 10019
    Another vote for the Hakko. I understand not wanting to spend that much, but I don't consider £150 to be a lot for a specialised tool that I've used a lot.
    I bought a great little stand recently for about £7:
    https://i.imgur.com/jIBqJzx.jpeg
    Brilliant for holding small pcbs but maybe not what would work well for for more irregular bits of guitar electronics (although I discovered yesterday that it holds a Tele control plate very well.)
  • Sorry to hijack, but I’ve just picked up a soldering station and am about to do a pedal kit. What sort of temperature settings are recommended for this sort of work?
    The Swamp City Shakers
    The solder should say.
    For lead-free I think I went 300°C but that was a while ago.
  • OilCityPickupsOilCityPickups Frets: 11994
    Exactly ... We use a 180w iron with a 1/2 inch tip for covers.
