We used a new rehearsal place today and it's at the top of a long flight of stairs I didn't want to haul my Engnater up them so I used the house amp which was a Fender Concert. I just set the EQ to 5 on each dial and then used the master volume to get a clean tone. I'm not a Fender amp guy at all, I lean much more to British sounds but I have to say this thing was really very very nice indeed on the clean channel. I didn't even use the dirty channel as I got dirt from pedals.
The guy mentioned that he might be selling it and I weas so taken by the clean I was wondering if I might make him an offer. What can people tell me about the Concert amps?
Values are not all that high despite this. Depending on condition, probably £400-£600 for the most common 1x12", a little more for the rarer 2x10" and 4x10" versions.
They are also quite valve-sensitive and need good ones to get the full power and dynamics - if you're lucky you may find most of the original preamp valves, but the power valves will usually have long since gone.
There is one known maintenance issue, which is an under-rated resistor in the bias supply that can fail and kill the power valves, but if replaced by a higher power one is then totally reliable.
They were developed with Paul Rivera as a consultant although he didn't actually do most of the design.
If you're going to buy one and want to use the distortion channel, make sure it has the footswitch - it's unique and expensive to replace or build a copy of.
