VHT Special 6 Ultra Amp Mods
jaymenonjaymenon Frets: 870
edited July 2023 in Amps
I just bought one of these.
The amp comes with a built-in power scaling feature. I understand at low powerscale settings, it's advisable to lower the master volume.
Unfortunately this amp does not have a master volume - and that is one of the mods (amongst many others) discussed here:
https://robrobinette.com/Special6UltraMod.htm
https://i.imgur.com/QEmQzDj.jpg
On this schematic Rob Robinette recommends placing a master volume after the effects loop.
So if I were to place a line level graphic equaliser (like a Boss EQ20) in the FX loop, will the output level control of the EQ do a good job substituting for a Master Volume?
Expert opinions deeply appreciated
  • Dave_McDave_Mc Frets: 2424
    Just out of interest, why is it advisable to lower the master when you're using the powerscaling? Most amps I've seen with powerscaling/VVR don't have a master...
  • jaymenonjaymenon Frets: 870
    Andy Talbot of RAT amps once advised me that at very low power scale settings lowering the master volume improves the tone.
    Oh ok, thanks! I was just worried it was dangerous- for the amp I mean.
