Parlour Sized Gigbag
Anybody have any recommendations? Up to about £50 maximum. Do I even need Parlour sized as maybe Concert will do just as well?
  • earwighoneyearwighoney Frets: 3592
    What is your guitar? How big is your guitar? I've seen the term parlour guitar used for almost anything which isn't a dreadnought.
    If you have a chance to measure the lower bout if your guitar isn't one which has it's dimensions online.
  • StratavariousStratavarious Frets: 3811
    I’m after same for Taylor / Martin mini … interested in a decent gig bag or light moulded case too.
    The Taylor GS Mini would fit in pretty nicely to a hard foam classical guitar case I imagine.
    Something like this would be my first point of call.
  • BillDLBillDL Frets: 8964
    I have a Cort mini that's probably roughly the same dimensions as a Taylor Mini, and I have it in one of those Harley Benton hard foam cases for classical guitars.  Check the internal dimensions and measure your guitar.  My Parlour guitar (albeit a 14th fret one) is currently in a well padded classical gig bag.
  • YorkieYorkie Frets: 1687
    I'd be very careful, because as @earwighoney has pointed out, there's huge variability across parlour models. My PRS looks like a small dreadnought, while others are narrower at the top and much wider at the bottom, almost as wide as a dreadnought. I was lucky to get a nice fitted gig bag with the guitar.
    Adopted northerner with Asperger syndrome. I sometimes struggle with empathy and sarcasm – please bear with me.
    My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
