I have been using it & can get to level 5 at the moment using songs to recognise ascending intervals.
I can usually pick out a 4th “born free” descending or a fifth if I remember (Andy pandy ending - Good Bye ) this gets you to level 5 or 6 . I’ve not learned many more ascending pneumonics but by picking them out on my guitar I can get to level 10 .
my pnemonics
minor 2 Jaws
M2 do ray / frer Jacque
m3 bond part 1 (you’ll recognise it when you play it)
M3 bond part 2 (as above )
P4 Amazing grace
#4 Simpsons /dissonant
5 Star wars
b6 First 2 notes of Baker Street
M6 from out of a wood did a cuckoo fly
min 7 Star Trek (old theme )
M7 take on me
Descending
M4 born free
5 Andy Pandy Good - Bye
Real world example....sure you know those song intervals to determine the difference between one note and the previous one. Great....you can transcribe stuff one note at a time by knowing how far it was from the next. That's about it.
Key centre hearing.....you determine the root note or the home chord in the key and hear every chord/note against that. What does this do? You can recognise and learn entire melodies in one go. You can analyse a tune at first listen. You can analyse the components of a chord in one listen. You basically know what you're listening to. You know what gets in the way? If you have extra and totally useless information popping into your brain like 'oh that was here comes the bride and now there's jaws and there's Star Wars.
Basically, stop the interval thing before you really burn those things in, and start doing key centre stuff instead.
https://www.thefretboard.co.uk/discussion/232677/
As @wizbit81 says though you will need theory to hear the key and relate the chords to each other
Being able to hear intervals is a big part of the picture
My advice....do 3 things....
1. Get Functional Ear Trainer (free app) and use that. It will be hard at first but you will learn to hear a note against a tonic and know it's function, what it is, but not by comparing to a mental list, you will just know. Then you can do 2 in a row, then 3, then infinite basically. It will also allow you to start doing 2 notes at once, then 3 etc if you have the time and patience for that. I amazed myself when I started being able to do 3 at the same time accurately.
2. Get the Beato Ear Training course. There's nothing around that replicates what that does in terms of teaching you many, many sounds.
3. Make playlists of chord types (all minor, all major etc) in all 12 keys and practice improvising to them on random, so you have to adapt in the moment to new chords.
4. Transcribe stuff and learn to identify the things you like so you can steal them and use them.
That's it really. There's a good 3-5 years worth of work there. If a million people pipe up with different opinions then fine, I won't argue about it. That's my opinion and it's based on a lot of work in that space.
If you use the mnemonics wisely they can help tremendously. But Wizbit's right, ultimately you'll need to know the notes and intervals you encounter in the music, wherever they lie in the scale, and you'll want to understand their functional purposes, and even more importantly, their musical effects.
Here's an example of the issue, but also how mnemonics can help, using the Major 6th.
So the major 6th is often exemplified by either:
My Bonnie Lies over the Ocean, the interval between "My" and "Bonn":
Or, The Day Thou Gavest, Lord, is Ended, the interval between "The" and "Day":
However, to wizbit's point, these two mnemonics are highly context-specific. They don't actually span the 1 to the M6 (the tonic to the submediant for the theory lovers) like many other interval mnemonics; they span the 5 to the M3 (the dominant below the tonic, to the mediant above it). Yes the interval is a major 6th, but it's really a 4th plus a major 3rd. Most examples of the major 6th in actual music span dominant-mediant in this way, so My Bonnie is usually fine.
However, If you want a major 6th constructed from the 1 to tonic-submediant you'd have to go to something like Meatloaf's Hot Summer Night - "You Took The Words Right Out Of My Mouth" - the interval between "You" and "Took". I don't suggest you click on it because it's revolting, but here it is anyway:
The intervals are both major 6ths, but they're in different parts of the scale, which is what Wizbit's stressing.
Where I differ from Wizbit, is that I think the mnemonics are still a great tool for beginners, and I don't think there's much evidence of them damaging peoples' ability to move beyond them. They've been used for hundreds of years by just about everyone. The trick is to let them fall away once you don't need them any more; but I believe that naturally happens anyway as you advance.
There is a very specific additional problem with mnemonics though: they don't cater very well for enharmonic intervals. For instance the major 3rd vs. the diminished 4th. We all know what a major 3rd is, and what it sounds like, but what is a diminished 4th? It's usually found in a minor piece in a harmonic minor or melodic minor situation, between the leading-note (M7) and the Minor 3rd (m3). That interval could (wrongly) be called a major 3rd because it's the same size, but it contains four notes.
I can't find a good video that combines a description of the diminished 4th with examples of its use. But you find it in loads of minor music, for example, the Pink Panther theme tune, which is in E minor; after the piano / bass intro, the sax comes in with the tune, and the first 4 notes span D# (the leading note) and G (the minor 3rd).
That interval is the same as a Major 3rd (well, Db to G would be be a major 3rd), but it's actually a diminished 4th, and you'd never use a mnemonic like While Shepherds Watch their Flocks at Night to recognise that interval, because the notes in between are wrong and the whole context and function of the interval is different.
I also get slightly triggered when people call a minor 6th an augmented 5th when it's inappropriate. But I don't like to make a fuss.
When I started with it I still used the mnemonic tunes ('star wars' etc) to pick out the intervals because that's what I'd been shown before, but I actually find the way it is in the app easier and just do that now. It plays you a little run of notes up and down to the note you want, and you learn to hear that, and what the character of each interval is. I've probably not explained that very well but the point is eventually you can just hear it and know, rather than work it out in your head.
As I say, I'm only at a fairly basic level and I can't do them all consistently, but it's helpful and quite fun when you start getting them right. I played in bands and wrote songs for years and hadn't even considered this. Because of that i feel like I know some of this stuff by feel but I didn't know the terminology before, so it's kind of giving you a structure to understand things you might already have absorbed subconsciously. I only really started learning theory a few years ago and this is part of that.
I’m only at the basic level but it’s very compulsive to keep having another go
