never mind
Works fine with my browser.
The packet states 'USA materials' and in the bottom corner 'Wound in PRC'........??
They are loud, and described by a non-guitar playing friend who is a musician as "sparkly". They are not as bright or harsh sounding as elixirs. There is a fair bit of finger noise to my ears which the old strings didn't have, so I'm hoping that goes away. Overall though I like them. Will be putting a set on the Martin (also for sale here) to see how they suit a different guitar.
If you noticed finger noise then that's probably the clincher. Fit the Elixirs & keep Everlux for next time.
I intend to get the guitar set up properly again so saving the strings for that. Fitting it in is the problem!
However - initial reaction was that the E & A strings felt like a rasp file on my fingers. This became less of an issue as I got used to them. Also I found the squeal factor a bit unpleasant.
Would I use them again? Yes if someone gave me a set as a present.
I changed them again (with a set up) back to Elixir pb and I feel like I've come home again. Everything sounds just as it should again!
