https://youtu.be/1wMqNRvMUsY
Eqd Speaker Cranker clone
So it turns out I already knew how to build a buffer – every boost, drive or fuzz pedal I've made so far is designed around that idea.
My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
There are some great resources on the AMZ site: https://www.muzique.com/
In particular, the MOSFET boost is well worth building: http://www.muzique.com/schem/mosfet.htm
R.
Some books I recommend
Small signal design - Douglas Self
Opamp cook book - various versions but once you see how versatile opamps are there's enough cookbooks to keep you in designs for years
https://www.rapidonline.com/intersil-icl7660scpaz-cmos-voltage-convertor-82-0788
The spec sheet there includes application schematics, but basically you chuck 9v in and get either -9v out or 18v (ish) so you get much more headroom in the circuit you're powering.
Opamp followers are a really basic configuration.
https://www.allaboutcircuits.com/video-tutorials/op-amp-applications-voltage-follower/
