Got this yesterday from my local Oxfam - it's a 1950s 'folk' guitar, possibly made by Höfner or Framus, but I'm not sure... 'Florida' is the brand on it but I think that may be for the British market only - it just says Made In Germany below the logo.
It came with three nylon and three steel strings! It was actually intended for steel - the nut grooves are too narrow for nylon, especially the top E - but the bridge is clearly more a classical design, and given that it's probably seventy years old, the top is bellying slightly behind the bridge and the neck has quite a bow in it already, I think it's much safer to string it with nylon. I found another old black nylon top E string to go with the B and G that were already on it - I had to open out the E string nut slot slightly - and fitted some hard-tension classical wound strings, but apart from that, it really needed nothing more than a gentle clean and the machineheads oiling - it's in really very good condition for a guitar this age. (I forgot - the bridge saddle was chewed up, but I had another in my box of old spares which fitted.)
The neck is quite chunky and the action somewhat high above the 5th fret due to the neck bow, but it's still perfectly playable with the nylons on it. It's not loud, and nor does it sound 'great' - I assume it's a ply top since the back is - but it actually suits me much better than my proper classical guitar which is just not really me...
My YouTube Channel
Silk and steels may be pushing it given the bow in the neck - even if it doesn’t cause further problems the action height will probably make it too hard to play. I’m happy enough with the nylons for those Leonard Cohen moments .
You don't say how much you paid?
