HX Effects users: How are you powering them?
The supplied PSU doesn’t look up to scratch. I’ve seen the Paul Cioks video of using a current doubler with the DC7. But is there any other way?
  • I just bought a generic 3A PSU on Amazon. Works fine.
  • stickyfiddlestickyfiddle Frets: 28141
    Stomp here but I use a current doubler adapter for Zuma and CS6 on the occasions it goes on my board
  • relic245relic245 Frets: 1037
    Don't suppose you have a link to that do you?
    Apologies, it was on ebay, not Amazon. Though I reckon these exist on Amazon as well.
    https://www.ebay.co.uk/itm/164036023219?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=DG5f9oj7TUi&sssrc=4429486&ssuid=GU1dc2hCRDi&var=&widget_ver=artemis&media=COPY
    Thanks for the link chap. Just ordered two of them.
  • BlueingreenBlueingreen Frets: 2675
    What's the problem with the supplied PSU? I haven't had any issues.
  • SnagsSnags Frets: 5494
    Ex-user here. I had mine on a small board and powered it all with GigRig gear. Note that the power plug is the "other" size so you need an adapter if whatever you've got is Boss-sized.
    First problem for me is that it's too big.
    I like to mount power stuff underneath my pedalboard but couldn't make it work with that and it is now taking up a lot of real estate on top.
    Also for me it's starting to break. If you wiggle the wire near the connector it cuts out. It's been known to do it mid gig with too much vibration.
    Ok. I get that the shape is a bit awkward but I’m not sure it would be enough to motivate me to buy a new one. But I don’t use it with a pedal board, it sort of is the pedal board.
  • Danny1969Danny1969 Frets: 10719
    The included one is a joke, mine broke after 7 gigs. I don't know if they are all the same but mine has the ferrite bead placed about 4 inches from where the 2 core DC cable exits the PSU .... any idiot can see what's gonna happen with that arrangement. The insulation will split at the area of most stress and the 2 conductors will short, which is what happened to mine.
    A better PSU option for gig'ing is a nice robust PSU with proper mains inlet and robust round & shielded DC cable ..like a laptop charger. Hipro make some nice 12V ones, I use one originally meant for a  DJ CD mixer
    Same issue here.  I had to resort to a glue gun to secure mine at one point.  Gave up on it.  I've read other people on other forums complain about these PSUs.
  • CirrusCirrus Frets: 8537
    Ex user of a Stomp, Cioks DC-7 with a doubler cable into a barrel adapter IIRC.
  • jellybellyjellybelly Frets: 792
    I've used an adaptor with both a GigRig Generator and a Strymon Zuma R300.
    GigRig was flawless (was just a pain to isolate other pedals from it). Zuma would often not supply enough current for it to boot, so it would get stuck in a loop without actually getting to the point of being useable. Sometimes it would be fine though.
    1000ma (2x500) is clearly borderline for it to boot and would be risky, imo. Don't know if cioks is the same but a GigRig solution (they have a new adapter for it, 'Mr Universe'??) would be my suggestion if you need to fit it under a pedalboard. An expensive rabbit hole to be sure...
  • zimmi_bzimmi_b Frets: 2
    I'm using a True Tone CS6 (the 7 and 12 work too). No problems - just make sure you get the polarity right!
  • DominicDominic Frets: 16340
     ^ me too
  • TimmyOTimmyO Frets: 7893
    I used a Gigrig Generator - split one to a L6 adapter to HX, and the other 'line' to combination of daisy chain and isolators as needed for other things. Generator does 5A total so worked well.
    Red ones are better.
