Evening all.
I have just acquired a modified jazz Bass and would really appreciate your help wiith identifying the model, year, value once tested and setup, parts and where i can pick up replacements.
- it appears to say Isonez? A copy of a copy perhaps?
- 2 machine heads have been replaced (E & A) but still appear to be of a similar age:
- Non-original wooden scratch plate. Assuming the original was tortoiseshell?
- Pickup configuration is a PJ hybrid but dont know what the pickups are. The routing for the PBass pickups is rather shoddy:
- Original “made in Japan neck plate:
- Assuming this is the original bridge and saddles?
- Strap button and strap lock on the base:
- Im guessing the control knobs are original?
- And then photos of the rest:
Any help with identification would be amazing!
It's definitely a very similar early/mid-70s Japanese Jazz Bass copy, probably from the same factory as the normal Ibanez ones - I'm fairly sure Matsumoku, but from before they gained their justified reputation for high quality.
The cream pickup is a DiMarzio, not original - it would have been another Jazz pickup. The bridge pickup, bridge and knobs are original. The top strap button is original, the bottom one isn't - or even a strap button, it looks like some sort of electrical screw terminal or something similar.
They're not worth a vast amount even unmodified, and it's debatable if the DiMarzio adds anything to the value - even though they fetch a reasonable amount on their own.
There's probably not a lot that needs replacing other than the pickguard - given the quality of the DiMarzio, it would probably be better to have a new guard made to fit it rather than revert to the original pickup, if you can even find one. It might even sound quite decent as it is...
The headstock wood and truss rod cover smack of MIJ budget brands such as Kay, Zenta or Satellite.
The machineheads resemble the Gotohs on my Squier Silver Series Precision. They all look a bit wonky. It is possible that none of them is original. Remove them and inspect the wood for evidence of reaming.
The split coils pickup resembles a DiMarzio Model P. The sealing resin on the underside is pretty distinctive. I have a similarly ancient pickup rescued from a Hondo II with the same general appearance.
flanging_fed “
Instagram - https://www.instagram.com/templemandolins
YouTube: http://www.youtube.com/@fromtheworkshop
I would just have a new one made using the wooden one as the template.
