Amp-wise, I think the lack of brown-face Fenders needs addressing. Maybe some modern classics like a Mesa Tremoverb or Orange AD too.
Effects - I think there's a few they could consider that are either classic or unique...
Crowther Hotcake
Nobels ODR-1/ODR-S
Marshall Guvnor/Shredmaster
Audio Kitchen The Big Trees Preamp
Boss BD-2 Blues Driver
Roland BeeBaa Fuzz
Zvex Octane fuzz
MXR Blue Box
DOD 440 envelope filter
MXR Phase 45/Phase 100
Reverse Reverb
Gated Reverb
Poly auto swell effect (like the modern EHX Attack Decay)
ZVex LoFi Loop Junky (Lo Fi looper)
Plus some additions/fixes:
- better auto swell. Zoom multistomp is way better!
- clipping options for the new RAT model
- Custom names for favourites
- ability to switch from a stereo path as standard to dual mono inputs or outputs. You can sort of do this at present by using a mixers with 100/0 or 0/100 values but would be easier to treat the two as separate if that's what you want. You need to 'waste' a block on the second input and use up one of your loops for the HX FX at present to do this too. Not sure about full fat Helix though.
Not that I think it's particularly lacking as is - continues to impress.
Also, it’s really time for some bass updates for a change.
Incidentally the bass di they have already is great and I have used it extensively with the poly Capo and crossover filter to mimic the boss OC-5's clever 'lowest note' mode and plug it direct to the board for bass tones.
You could do a through-zero flanger and two multitap delays at the same time (for example).
Mark Bass AG1000
Ashdown ABM Evo 4 (or the new 5)
That would keep me happy.
If you haven't tried it, I'd suggest the Legendary Drive is pretty face-meltingly heavy - can dial in some really great heavy settings or replicate other stuff with its EQ - really flexible
Once they've done all that, then crack on with more modelling
Hoping as per my post, the they do another SansAmp for guitar...
